Follow up so far I did replace the BR21 even thou the stock appeared to test good.
It was very easy to remove I had no issues I always cut the legs on the spade type legs.
I then use locking forceps to hold the tabs while heating and they slide right out.
I use the Hakko to clear out the solder. I then clean everything with alcohol.
With that said I discovered that the Display power board was connected and once disconnected the fuse no longer blew ugh it was probably that to begin with.
I now have 20 v however there is no blanking signal and the flashers are all locked on when the coin door is closed
The toilet lid was also locked on as it went up (along with the flashers) when the coindoor was closed
I replaced Q5 the toilet driver and the toilet lid stays put.
Is it possible that all the flasher drives are shorted?
Why is there no blanking signal?
Something must have happened to cause all of these issues along with the display power board causing fuses to blow.
So as it stands I have flashers locked on, No display and no Blanking so no booting up.
