Goodmornig! I try to fix the pinball of Baywatch SEGA '95.
I start with the knocker's coil and with a flash-light on the ramp witch dont work, i took a look on the electric diagrams and i saw that there are connected both on the darlington's transistor TIP122 called Q39.
This transistor, placed in cpu board, was broken. Then I change it and I turn on the pinball but the problem was the same. I took a look on the coil, the wire war connected in the opposite way, fixed it and replaced Q39 (broken down again) i turn-on the pinball but the now the problem are increased. Now two Sling-shot (left and right), the two Bumper (right and bottom) and again the knocker don't work, also a fuse (4 Ampere) called F5 on the source card (PPB) break-down. I control the transistors of these coil but are ok, i look the diagrams on the manual but i have no idea what is the problem.
Sorry for my bad english, I hope that someone help me
