(Topic ID: 130700)
Sega Baywatch Display driver board voltage problem
By Brandje
5 years ago
  • 15 posts
  • 6 Pinsiders participating
  • Latest reply 5 years ago by thedefog
#1 5 years ago
Ok, I'm i need of some assistance here.
I have a problem getting the display board on my baywatch to work, Ive been reading alot about how these things can cause lots of trouble with the slightest deviation in the 5 volt line.
Now when its powered on, without the display board connected I measure a steady 5 volts, but with the board connected, it drops to around 3 volts.
any help would be appreciated
#2 5 years ago
check the bridges and the caps, most of the time it is the capacitor leaking causing lower voltages. I have had to do this on 2 baywatch machines and one frankenstein
#3 5 years ago
So you mean the caps on the display board, or power board?
#4 5 years ago
These are the Power Supply Board in top left.
#5 5 years ago
Wel that's the strange thing, all my voltages are ok.
I hooked up an external 5 volt to my display board, and as soon as I connect it power drops to 3 volts again, this thing is driving me nuts :p
#6 5 years ago
Have you done the upgrade kit to the power wire yet? http://mad-amusements.com/product.php?id_product=1379
I realize they are out of stock, but Pinballife usually has them, but their website is down until the end of the month.
Here is a link to the bulletin: http://www.sternpinball.com/upload/downloads/sb106.pdf
#7 5 years ago
Quoted from PTHermes:
Yes, the kit itself takes 5 minutes to make yourself if you have some wire and IDC or molex connectors. Resolves some of the reset issues.
#8 5 years ago
Kit is already installed, yet the problem persists, nice 5 volts when not connected but a drop when connected.
#9 5 years ago
Quoted from Brandje:
5v cap replaced on PSU?
#10 5 years ago
Does the game even boot when the display board is connected? If the voltage drops to +3v, the CPU probably won't boot either
#11 5 years ago
If the external power supply provided sufficient current to the DMD then something on the DMD board is pulling the voltage down.
#12 5 years ago
ordered some new caps for the power board, but I'm still convinced the problem is in the display board.
Quoted from Hana9so:
Yes, boots just fine, i can play without any problems, just no display
Quoted from terryb:
My thoughts exactly, but i cant figure out what.
#13 5 years ago
This type of issue is not easy to narrow down. It's often easiest to cut the 5 volt traces to narrow down the issue to a general area and then narrow it down from there by removing components.
#14 5 years ago
found a new display board, and things are up and working again, no clue what caused the other boards problems. thanks for all your help!
#15 5 years ago
Good to hear.
€ 339.00
Displays
GermanGamingSupplies.com
Gweem's Mods
$ 24.00
3,500 (Firm)
La Verne, CA
PinSound
Professor Pinball
