Hi,
the lower right flipper coil gets hot quickly. As a result, there is no strenght enough to climb the left ramp. When I put the DMM black lead on the ground and positive red on the coil lugs, I do no get any measure although the relay has activated the bats.
1. what can Be the reason for the hot coil ?
2. why do I not get any voltage with the DMM ?
Thank you so much for your responses
