See attached pic.
So you can see the contrast in what the playfield is, vs. what it was. LOTS of plays on the machine. Ball tracks and everything.
Which Novus to use to clean it up? 1 or 2?
I also got the foam (sponge) applicators from Pinballlife. Use these, or something else?
How long should I work the product into the playfield to clean up the buildup? i.e. should I do a little at a time to see the progress to avoid overusing the abrasive?
Also, is it safe to go over the plastic lenses on the playfield, or is it just for the wood/paint part of the playfield? How about the clear plastic ramps?
I plan on disassembling almost the entire playfield, replacing rubbers etc., so I will be able to reach every area of the playfield.
I am asking for advice on what to do/what not to do, because I’ve never done this before and I don’t want to ruin the playfield paint.
(And yes, I already have the plastic canister of Blitz wax ready to go to put the !!! on this project)
