Trying to bring this one back from the dead!
Picked up a seawitch project with a restored original Playfield.
With that said some of these problems can be anywhere because I am not the one that populated it. (not that I would have created a prob myself)
Pictures of Voltages on paper of all boards and test points to make easier.
I started at Transformer and rectifier board. Transformer is voltages are good. The rectifier was showing incorrect voltages so I replaced it, and this is what Im getting.: alsoSEE PIC
The test point that is throwing me off is TP3. I have 14.2 with new board. It is not in line with Pinwiki (11.9 +/- 1.4, but close. I have a stars that plays 100% and it measures 14.34 which is also not in line with pinwiki but plays 100%
Pictures of my other test points are shown in pic of MPU, Driver and lamp.
Test point TP2 is 13.83 and wiki has it at 11.9 +/- 1.4
The board that I am completely lost on is the Lamp board which is -5.38 and should be positive 5.
The main issue is when I turn the game on the 1amp SLow blow is blowing. it doesn't blow fast, it actually takes 30 + seconds. Im guessing there is something grounding out under the PF. Also previous owner took out period correct flipper mechs and put in 90's bally Williams. I will probably convert back to original when I figure all this out.
also are pics of connectors going to rectifier. previous owner repined. I want to make sure wires are correct. I'm going to do all new connectors anyway.
THank you in advance for any HELP!
