(Topic ID: 129631)
Seawitch not going into Test mode [solved, kind of]
By L_satan
  • 6 posts
  • 3 Pinsiders participating
  • Latest reply 3 years ago by L_satan
#1 3 years ago
Like the post says, not quite sure what is causing the trouble. Neither will the high score reset button work. Loose connection, perhaps?
#2 3 years ago
I just got done trouble shooting my Time Warp with the same issue.
It turned out to be a cracked solder joint or cold solder joint.
#3 3 years ago
I shall look at that tomorrow. Both buttons do nothing, and did work not long ago.
1 month later
#4 3 years ago
SO, I finally got to it, and the boards had been serviced by barakandl, who is AWESOME--needless to say no cracked solder joints. I have not replaced all the plugs, which I will do soon. After wiggling them, nothing. I looked in the coin door, and followed the Yellow/Red wire, up to the cabinet plug and there was a pile of electrical tape around the wire and a funny additional wire going to the braided ground.
Removed the tape and WOW lots of exposed wire joints. I quickly soldered them, and the coin door test and reset switches are fine.
Now, why was that ground added to the Y/R wire (which is cut excruciatingly close to the plug)? Is this normal? Seems like a hack. Truly.
Should I remove it and trace the problem, or leave well enough alone?
#5 3 years ago
It's a hack. That wire connects to ground at J2 pin 7 on the solenoid driver board. There's probably a bad pin in the J2 connector so someone just made the ground connection near the cabinet plug.
#6 3 years ago
Thanks, dothedoo. I will deal with that properly Wednesday night. Nice game collection!
Displays
PinballSolutions.eu
$ 45.00
Pinball Photos
Third Coast Pinball
$ 19.95
$ 55.00
Pinball Photos
$ 7.65
Cabinet Parts
Third Coast Pinball
$ 399.95
$ 3.00
Doc's Pinball Shop
3,500 (Firm)
Toronto, ON
$ 14.50
PinballElectronics.com
$ 45.00
Pinball Photos
Great pinball charity
Pinball Edu
