Hi all,
I'm having a boot issue with my Seawitch and I cant seem to figure it out. After the 3rd ring the MPU freezes up and makes a continuous screaching noise. After messing with it for a bit I am at a dead end to the issue. If I leave J2 on the lamp driver disconnected the game will boot completely and the displays light up correctly. From what I am seeing on the schematic is that J2 controls several of the feature lamps on the playfield. What I have tested/done so far:
Swapped all the boards in the backbox with known working ones
Repinned J2 on the lamp driver after seeing a bunch of "green goo" on the black/white wire connector
Tested several combinations of leaving different connectors unplugged on the MPU, Lamp Driver and Displays - at this point I am sure that it is the Lamp Driver J2 that is the issue
Can anyone point me where to go from here? Thanks in advance
