Search time...... too long
By JKnPA
1 year ago
Stats
  • 7 posts
  • 2 Pinsiders participating
  • Latest reply 1 year ago by bingopodcast
Find
Search this topic for posts matching certain words or written by a specific Pinsider. Or both!
#1 1 year ago
The 'search time' on my 'Showtime' gets longer as I keep playing it.
It runs for about 3-5 sec. at first , then the time gets longer to complete the search cycle
as my playing time goes on. After about 15min. playing time , the SEARCH cycle takes about
20sec.
Is this a mechanical adjustment on the Timer cam, or is the problem somewhere else?
John
#2 1 year ago
That's not normal. I forget, does Showtime have an 'R' button to begin searching, or does it do a constant search?
Also, when you say searching, do you mean the process of searching for and finding winning combinations, or do you mean the process when you put in a coin and it searches for an odds increase or etc?
My suspicion is that either your control unit motor needs to be oiled, or your clutches need to be oiled.
I can provide methods to do so without disassembly, but just want to confirm that's what's happening.
#3 1 year ago
**** do you mean the process when you put in a coin and it searches for an odds increase or etc? **** YES
When I hit the RED button to get better ODDs/Features.
*** I never put coins in any more; I always have Many Credits available; one way or the other...
#4 1 year ago
Ha!
Well, the timer cams index does allow for movement, and the mixer latch allows for the light show when you press the button.
Check control unit cam 3A - that switch allows for basic gameplay to function. If it's opening and closing as the control unit rotates, then it's probably not that.
My first suspicion is that the control unit motor needs oiling (there are two brass filling tubes that stick out from the motor - use 3-in-1 motor oil in the blue_ can. Not 3-in-1 in the red can. Put a few drops in each tube, then turn the game on and let the motor run for a few minutes. Then do so again. If the oil comes out the bottom, then move on.
Next, check the edges of your clutch washers - there's one set in between each portion of the control unit. In Showtime, there should be two sets.
The timer cams are the ones in question - if they are sticking, then the motor won't be able to finish rotation, which keeps the mixer latch active.
To add oil to these, I will /carefully/ use a flathead screwdriver and pry the piston-type thing from the washer. Then, I'll use a syringe to inject neatsfoot oil (comes in a cylindrical container) onto the clutch washer directly. Wipe off excess that drips with a paper towel. Then rotate the control unit (you can do so by hand - and you'll want to do this with the game off). Then do the other side. If this one set needed it, the others may as well. There are also clutches on the mixer unit at the top of the back door that separate the mixers from the spotting disc.
If the motor is laboring, then your motor needs attention. If it's not laboring, then it's probably a clutch-related issue. A little oil wouldn't hurt the motor, regardless. The mixer motor also has filling tubes.
Remember: 3-in-1 motor oil in the blue can for the motor filling tubes, neatsfoot oil for the clutch washers.
#5 1 year ago
I just put some neatsfoot oil on the clutches; I didn't see any difference in the 15mim. period, but maybe
it needs more time to be effective.
I will look at it tomorrow again.
Thanks ..... I will save your post.
John
#6 1 year ago
I placed some neatsfoot oil on all the timer cam clutches. The 3rd one looked like it had the most wear.
I didn't see any issue with the drag arms or pins, but I put a touch of oil on them anyway.
I just played the Pin for about 45min............. no delay times were noticed.
Therefore I think the issue was the #3 clutch.......
I will re-check it tomorrow!
Thanks 'bingopodcast'
#7 1 year ago
Absolutely! Always happy to help keep a bingo going!
$ 989.00
$ 5,699.00
Operation Pinball
$ 76.95
$ 159.99
$ 22.00
$ 209.99
PinballBulbs
CzTV Mods
$ 29.99
$ 160.00
Professor Pinball
$ 69.99
$ 7.00
APB Enterprises
$ 28.00
$ 2.50
Third Coast Pinball
$ 27.99
Lee's Parts
£ 49.00
PinballToys
$ 48.00
Bright Lights Pinball
$ 29.99
Lee's Parts
Note: This is an old thread. The last post was made to it 709 days ago. Resurrecting old threads is not necessarily a bad thing, if you think the topic is still relevant and/or your post is beneficial to it (e.g. following up on something). In other cases, it might be better to create a new topic.
Wanna join the discussion? Sign up for a Pinside account, or log in if you already have an account.
