(Topic ID: 294792)
screw size and type
By hoodie75
2 years ago
  • 13 posts
  • 6 Pinsiders participating
  • Latest reply 2 years ago by pinhead52
#1 2 years ago
i have a williams super star (72) that i picked up. its my first table and the former owner took it apart and didnt give the bag of screws. the posts are on the playfield. i have the upper arch pieces and the bottom apron. i was wondering if anyone knew the type and size/length so i can put them back on. thanks in advance.
#2 2 years ago
Quoted from hoodie75:
Gottlieb was pretty uniform in its screw/post usage on the pfs, you can put together one of those blindfolded. Williams and Bally seem to be all over the map, maybe I havnt done enough Williams yet.
Hopefully a current owner of this game can setup and give you some guidence
#3 2 years ago
You can look here : https://www.ipdb.org/machine.cgi?id=2446
There are pictures of the playfield.
You should be able to get 90% of the layout from the pictures.
This site also has the schematic and manual.
The manual on page 8 shows the rubber sizes and their related post positions.
https://www.ipdb.org/files/2446/Williams_1972_Super_Star_Manual.pdf
Usually the apron and arch take the same screw size. I count the holes and find the match number of screws.
#4 2 years ago
If no one knows, I’ll pull the ones from my 71 Klondike this weekend and let you know what they are, if that will be any help. I’m guessing 2 1/2” size 8 wood screws.
#5 2 years ago
Quoted from AndrewP:If no one knows, I’ll pull the ones from my 71 Klondike this weekend and let you know what they are, if that will be any help. I’m guessing 2 1/2” size 8 wood screws.
Thanks I appreciate that. I have a feeling that the top arch is #6 sheet metal screws
#6 2 years ago
Apron is 8 x 2 1/4 wood screw.
Arch is 8 x 1 1/2 wood screw.
YMMV.
931EB027-3403-4656-B7CA-8D7EFC008E7F (resized).jpeg931EB027-3403-4656-B7CA-8D7EFC008E7F (resized).jpeg
02D7EEDB-0673-4CB5-8055-0C250CF509D7 (resized).jpeg02D7EEDB-0673-4CB5-8055-0C250CF509D7 (resized).jpeg
#7 2 years ago
YMMV.
You are a life saver!!!! Thank you very much.
#8 2 years ago
I probably have some of these if you need
#9 2 years ago
Quoted from pinhead52:
It’s all good, there is a Lowe’s right down the street and they will probably have them. It seems like a common part
#10 2 years ago
probably not the 2 inch number 6
i did find them at bolt depot
https://www.boltdepot.com/Sheet_metal_screws_Self_tapping_Phillips_pan_head_Stainless_steel_18-8_6.aspx
#11 2 years ago
Ace generally has a better selection of the off size stuff than the bigger stores.
#12 2 years ago
And they should be wood screws not sheet metal screws.
#13 2 years ago
Quoted from KenLayton:
I only buy sheet metal screws, seem to have deeper threads for grabbing the tired wood. If I dont have nice nickel plated screws I replace all on the underside with sheet metal "Stainless" 3/8s and 1/2 inch, flat for gottlieb, phillips for williams/bally. Pimps it up a little bit in my opinion.
Ken
This page was printed from https://pinside.com/pinball/forum/topic/screw-size-and-type and we tried optimising it for printing. Some page elements may have been deliberately hidden.
