(Topic ID: 169608)
Screw do not hold
By Luppin
7 years ago
  • 5 posts
  • 4 Pinsiders participating
  • Latest reply 7 years ago by Luppin
    #1 7 years ago
    First of all sorry for my bad english, not a native speaker and quite hard to describe technical stuff.
    So, my problem is with the screws that attach mechs to the playfield, under the playfield. Some of them, when being screwed in, keep turning endlessly and do not hold tight. Basically the hole in the wood, filled by the screw, is damaged.
    Unfortunately all four holes relative to a single mech are damaged in this way, so the mech no longer stick tight under the playfield.
    How to solve this situation?
    #2 7 years ago
    in the past when I have had a wood screw fail due to hollowing out of the wood, I simply drill the hole completely through the playfield and then use a machine screw with a star washer/nut on the bottom. be careful when drilling the playfield, and use as close to the same diameter that you can. see attached pics.
    this has worked with star posts and other items where originally a wood screw was used, but failed.
    #3 7 years ago
    Alternatively, you can drill out the stripped hole and glue in a dowl of the same diameter you drilled the hole out. Now you have fresh wood to screw into.
    #4 7 years ago
    Dip a shish-kabob skewer or a few tooth picks in wood glue. Stick them in the hole and snap off flush and let the glue set.
    #5 7 years ago
    Thanks much Taxman! I did what you suggested and it worked wonders! Mission accomplished 100% !!
    This page was printed from https://pinside.com/pinball/forum/topic/screw-do-not-hold and we tried optimising it for printing. Some page elements may have been deliberately hidden.
