(Topic ID: 114617)
Scratchy volume control POT on System 80
By ForceFlow
9 years ago
  • 17 posts
  • 7 Pinsiders participating
  • Latest reply 9 years ago by Syco54645
#1 9 years ago
Is there a go-to cleaner you can spritz in the volume control POT in the cabinet of a Gottlieb System 80 (Time Line)?
Any adjustments to it makes the sound crackle with static.
#2 9 years ago
Nope. They corrode over time. You can twizzle it a bit to "knock off" some of the corrosion and reduce scratchiness, but the only real solution is replacement.
Chris Hibler CARGPB #31
http://www.Team-EM.com
http://webages.charter.net/chibler/Pinball/index.htm
#3 9 years ago
You could try Deoxit. but like Chris said... I would just replace.
#4 9 years ago
I use Nu-Trol. It's made for volume controls. Catalog # 401B-140G (barcode: 779008401149).
http://www.mgchemicals.com/
You can also use Radio Shack 6400148:
http://www.radioshack.com/radioshack-control-contact-cleaner-and-lubricant/6400148.html#.VKtjH8lp2So
#5 9 years ago
By the time you buy a new cleaner you are halfway to buying a brand new pot that takes no time to instal.
#6 9 years ago
Quoted from ChrisHibler:
I figured that might be the case. Oh well.
According to a system 80 manual for a different game (I don't have the one for this game yet), it's a 100 ohm 2W POT.
I did some digging and found this, which looks pretty close to what is in the machine now:
http://www.digikey.com/product-search/en?KeyWords=53C1101-ND&WT.z_header=search_go
Or is there another preferred go-to source for these kinds of POTs? GPE and bigdaddy didn't seem to carry them.
#7 9 years ago
Damn. That's pricey. Partially because it's RoHS compliant. Check the RatShack. They might have one. You can also use a 500 ohm pot. It works, but is more sensitive.
Chris Hibler - CARGPB #31
#8 9 years ago
$4.50 from BigDaddy... halfway down this page... 100 Ohm, 5 Watt, Volume Control Pot
http://www.bigdaddy-enterprises.com/electronics/e_resistors.htm
#9 9 years ago
Quoted from Snux:
That one is rated for 5W. Can I use a POT rated for more than 2W?
#10 9 years ago
I usually take my POTs apart and clean it out with an eraser. Did that on my truckstop and it worked great.
#11 9 years ago
Quoted from ForceFlow:
Yup. It's rated =up to= 5W, so it will be fine.
Quoted from Syco54645:
Wow...a new level of frugality!
#12 9 years ago
Or I was too lazy to dig out the manual to check the specs and order a new one. It took me 2 minutes and worked perfectly. No reason to order one and wait a week for it to come in.
#13 9 years ago
Just to give it the ol' college try, I went ahead and took the POT apart. There was a little bit of grime / black dust in there, but after cleaning and reassembly, it worked good as new.
Thanks for all the info guys
#14 9 years ago
Nice! Nothing better than a fix that's free, and thanks for putting the resolution in your thread.
#15 9 years ago
Nice. Sometimes it seems like buying a new part is the easier and quicker resolution to a problem. Not always the case, as you've just shown
#16 9 years ago
Quoted from Snux:
Yep...I didn't even bother desoldering since there was enough slack on the wires.
I put the loose parts in my ultrasonic cleaner, and wiped the rest off with a paper towel with some simple green on it.
It only took maybe 15 minutes.
#17 9 years ago
Glad it worked out for you
$ 83.00
PinballReplacementParts
This page was printed from https://pinside.com/pinball/forum/topic/scratchy-volume-control-pot-on-system-80 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
