Hello All,
After connecting the missing wire, I am back to my original issue as it existed when I bought the pin. The unit powers up fine, all diagnostic tests succeed (solenoids, etc.). The MPU lights flash briefly and stay off when tested. No obvious board, connector or wire issues that I can see visually.
The game does not start. Apparently the issue was intermittent before I picked it up (it either would work fine, or the "ball in play" light was flashing, and it would not start). I assumed on pickup this was a bad ball trough switch.
I checked the trough switches, and they all seem to react. I have manually massaged them to look for an impact. I manually played with the start switch and wires, but unless the EOS is totally shot and I just cant see it, I dont see anything wrong with the contact. Manually making contact and adjusting wires, checking connections doesnt help. All connectors checked and reseated.
It goes thru all the adjustment and diagnostic tests just fine. No lights stay on the MPU board indicating a chip lock, etc.
One note: I cannot get the settings to change in the adjustments menu using the start switch. I made sure it has credits (no longer on freeplay after I yanked the batteries of course off). I replaced the MPU AA's and checked the solder and wiring to the external battery rig.
Not being able to change settings in the menu via the start button makes me think again that it is the start button switch. Anyone know how to easily test this theory? I have a replacement type that will work among my pile I am sure, but would rather not pull out the soldering gun until I have eliminated other options.
Thanks for your input!
Mike
