(Topic ID: 190580)
Score reel resets fine but coil won't fire during play
By n1teowl
  • 7 posts
  • 4 Pinsiders participating
  • Latest reply 4 years ago by n1teowl
#1 4 years ago
I have a Solids N Stripes that is acting strange. The 10's reel resets fine, but won't score during play. When a ten point target scores, the 10 point relay fires and nothing happens. This means that the relay locks and won't release. When I manually actuate the 10s reel EOS switch it releases the relay. The other score reels work fine. What causes the coil to fire on the 10s reel? Thanks a ton for any help you can provide.
#2 4 years ago
So if you manually actuate the 10s Relay in the head of the game does it fire on the reel?
#3 4 years ago
No, the reel doesn't fire. That causes the coil to lock on, along with the coil on the match unit. When I break the EOS switch (NC) on the score reel, they coils both release. The coil on the 10s unit never fires. I know it works though, because if I change the number manually, it will rest back to zero without a problem when I start a game. Thanks for the reply.
#4 4 years ago
Post the schematic here (or better, to IPDB) and we can help you trace the circuit for the 10s reel.
#5 4 years ago
Well, that's part of my problem. No schematic
#6 4 years ago
Look for a broken wire at the switch lugs associated with the 10 point scoring relay as well as checking the contacts for proper closure.
Have you taken the 10 point score reel apart and checked all of the contacts and checked for any broken wiring?
#7 4 years ago
Thanks for the replies. I found the instruction manual on IPDB and was able to trace back from the 10s unit to the player unit and found the switch that energizes the 10s scoring reel. It needed a good cleaning and that took care of the problem. I appreciate your help in thinking through this.
