(Topic ID: 204382)
Score Reel question
By Chrimeg
6 years ago
  • 7 posts
  • 3 Pinsiders participating
  • Latest reply 6 years ago by Chrimeg
  • Disco Stern Electronics, 1977
#1 6 years ago
Recently acquired Stern EM Disco pinball game. Few issues I had to work thru with unresponsive playfield, typical gummed up steppers etc.
Anyhow I got everything working and the score motors were sticky. Removed player one score reels, cleaned and put back in place. Ran thru a few games and all worked well.
Started two player game and all worked well but the two player score reels were all sticky. Game ended, turned off machine, removed first score reel (do one at a time and test) from two player side, cleaned, put back together and tested. Now when starting a game it keeps going thru the reset sequence (single player/can't get into the two player feature because its stuck in reset sequence). All player one reels reset as normal but the game just keeps looping.
Start game relay stays engaged. If I manually pull it open the ball ejects and game plays fine.
I've rechecked the score reels and all looks good. For the life of me I can find the problem. Is it a coincidence that this just happened after player 2 reel was cleaned? During 1 player game does the 2 player reels also have to reset?
At a loss here and could use some suggestions.
#2 6 years ago
Quoted from Chrimeg:
Yeah all reels have to reset to 0.
Check all the zero position switches on the reels to make sure they are making a good connection. You can test them by jumpering them closed and seeing if the reset completes.
Also give all of the switch wires on the reels a tug test. You may have a loose wire in there.
#3 6 years ago
Ok so all 2nd player reels have to reset too 0 as well. Wasn't sure if that was required during 1 player game but it may explain what is happening as it only started happening after initiating the first 2 player game.
I'll pull those reels this evening and see what happens.
I'm hoping it's not one of those wiper fingers...can find replacements anywhere just in case.
#4 6 years ago
the wipers on score reels typically are only for match and shouldn't have anything to do with resetting
#5 6 years ago
Alright so I've moved forward a little. Its in the process of resetting player two reels. Setting these reels manually the game plays fine. Both player one and player two score points and reels move. However, when the game ends and I start a new one. The player one reels reset fine. Player two reels do nothing. They have to be reset manually and the game works again.
I jumped the solenoids on player two from player one and they fire during the reset sequence. So it has to be in the reset side of player two somewhere.
Any ideas anyone?
#6 6 years ago
The problem is most likely in the switches on the score reels that open when those score reels reach zero. That's how the Reset relay knows when to let go.
#7 6 years ago
Found the problem to be in score motor impulse switch. Seems two are listed in this cabinet...assuming one is for player 1 and the other for player two. Re-adjusted switch, cleaned and now player two score resets as needed.
Looking over the switch banks they all need cleaning by the looks of it...score motor switches look very intimidating thats for sure.
This page was printed from https://pinside.com/pinball/forum/topic/score-reel-question and we tried optimising it for printing. Some page elements may have been deliberately hidden.
