I have an intermittent problem with the 100K score reel sometimes scoring when other level of points are scored. (this is fixed and solution is in the thread)
I have noticed that the problem only occurs when the score motor is in a certain position. When the score motor is in that position switch IMP-B arcs and this is when the problem occurs with the 100K score reel.
See video.
Around the 8 second mark is when you can see the arcing. This is also when the 100K score reel plays up.
I have adjusted the switch gap several times and have made no difference to the problem.
Is this where the problem is coming from or is there something else I should be looking for?
Attached is the incomplete schematic and the section I think the problem is occurring.
Thanks for your help,
Steven
PS: As part of this post we investigated the scoring of the drop targets. There is a jones plug which allows you to adjust the value of the drop targets. The targets can be set for 50k or 10k. This allows you to have a lower scoring game, making it harder to clock the score.
