Hi,
I have a Gottlieb King Rock that the player2 10000 point score reel coil stays energized when resetting
Game works perfectly all around but only for player2:
If the score is 10000, the 1 coil stays energized and K relay also stays energized
If the score is 11000, both 1's will reset to 0
If the score is 15000, the score will get to 60000 and then the 6 stays energized and K relay also stays energized
When the 10k stays energized and I manually move the 1k, then they reset normally
I've been trying to figure this out without schematics...
EOS of 10k is adjusted correctly
1k switches are all open when at 0
player 2-3 reset relay seems to be adjusted correctly
thanks in advance!
