Hi gang
I have a gottlieb 70's surf champ
It runs thru start up and everything seems to reset But the score motor keeps running,
If I hold extra pressure on the brake 3 1/2 spring, the motor will stop and I can begin playing but if get a bonus or hole, the related arelay K,I,G, ect will start the motor and it won't shut off unless I hold extra presure on break with my finger,I thought the break spring was too weak so I put in a good used one but same thing, I read alot of repair info and they say the 3 1/2 break is almost not needed? There is no voltage with motor at home unless 1C cam lever is lifted or a related score motor relay on,
I appreciate any help or advice
