I just got a 1967 Williams Jolly Roger game. I cannot get the score motor adjusted properly and was hoping someone could give me the best strategy.
Score motor will continuously run until I lightly press down on index switch stack. Everything else will work at this point. I put paper in MOTOR RUN leaf and stops motor so that seems to rule out all other switches.
I have been adjusting for hours. If increase gap too large the SM will not index to home position. Too little and continuous run. I have found a place where it will stop most of time. When at this happy medium it stops a bit late where it is half way up cam edge so outhole switch is disabled.
Seems like the motor momentum will not allow it to stop at full home position. So what do I do to fix this?
Thanks,
Kent_Diego
