Hello- Wondering if anyone can help. When I squarely hit the Scoleri Brothers targets, they often stay up, however, if I skim them on the sides or non-direct hits, they tend to go down. Any way to get them more consistent?
Some people buy and install new springs from Pinball Life.
While some others, myself included, have 'tightened' the currently installed springs by hooking them about 10 rungs of the spring tighter.
I made a video showing the modification the way DRUTHEFU explained it by adjusting the springs. The Pinball Life springs did not work for me
I had the pinball life ones on and they were too strong. The left target wouldn't stay up at all and the right would drop even if a ball lightly hit the back of it. I did the strengthening thing with he original springs but still get some bricks on squarely hit shots whereas glancing blows seem to be better. Gonna try and tweak it more. At this point I'd rather have them fall down too easily as that is way more fun than bricking shots off them and definitely helps the scoring out better!
Just backhand the targets... 6/10 times i can hit both in one shot with a light backhand toss. If that doesn't work the backhand hit moves to the opposite flipper almost every time (it's a quick catch)
One issue I'm having is the right drop target doesn't come up, anyone else experience this and have a fix?
Quoted from beepbeep:One issue I'm having is the right drop target doesn't come up, anyone else experience this and have a fix?
If the spring has been replaced with the ones from Pinball life it can just be that the spring is too strong. When I installed them on mine the left one worked fine, but the right one would never come up because the spring was just too strong.
Quoted from Jenk540i:If the spring has been replaced with the ones from Pinball life it can just be that the spring is too strong. When I installed them on mine the left one worked fine, but the right one would never come up because the spring was just too strong.
I still have the factory springs on
I'm experiencing the same, but I cant seem to figure out the fix yet. I tried stretching the spring a bit, no luck. I see it tries to pop up, but then drops right back down. I'll call Stern on Monday and report back here.
-=s
Quoted from scheiny:I'll call Stern on Monday and report back here.
Just talked with Chas at Stern. He showed me there is a "ledge" that the Scoleri rests on when "up" Compare the non broken side to the broken one, and you will set it was likely over tightened at the factory, and it may have broken. Without the ledge which is a small plastic piece screwed into the bottom of the play field, the drop target doesn't have anything to grab onto, and it will fall back down every time.
Call Chas and he will send you a new part to fix it, no charge.
My right hand Scoleri Brother does not pop up at least half the time. All appears normal and I have checked for loose connections. The left brother works every time. Does anyone have a suggestion? Thanks for any help.
This page was printed from https://pinside.com/pinball/forum/topic/scoleri-brothers-targets-issue-ghostbusters and we tried optimising it for printing. Some page elements may have been deliberately hidden.
