Luckily, I was able to easily rule that out, as I have no coin door at the moment. This is why I jumped to the next stage, the 'GAME' relay..
Quoted from frb:The game relay is latched thru the zero position switch on ball count.
Yup! So, I started looking at the 'GAME RE. LATCH', which is the coil that wasn't energizing when it should have been. I started looking at the ball count unit. My game had some odd changes made to it in its past life, and looking at it, I noticed that one of the wipers wasn't straight. However, turns out that that wiper isn't even related to my issue. The two wipers that were.. seems fine. Continuity at ball index 0, as expected. Jumped back to the Coin Relay, as it has a switch in series. That checked out as well. This is the part I'm looking at now:
Which made me want to ask:
What is the "C" there mean? It's not a listed wire color code. And the "IND A" tells me it's the Index cam, switch A. This is correct - took the Index switch stack off, bottom switch stack has a Red-Green and Black-Yellow on it. THAT also checked out.
So, that means that somewhere in my Red-Blue wire, I'm losing continuity. At this point it also occurred to me that the Red-Blue is likely going straight from the ball count unit to the credit unit. So, start looking at the wires there - found it!
This picture is taken after I moved the wires around, but there's some odd cut in both Red/Blue wires here, where then all four were twisted back together. I haven't technically fixed it yet, as I'm going to do it right and all (and ran out of time today to take care of it). But, I know what I'm doing tomorrow after work. And this should fix it then. Whew.
Thanks guys for the pointers, it helped me follow everything through and get down to it.
