My learning curve on this Toledo EM has flattened. I was checking continuity on Cam switch #1D (M-B) and I am getting a a positive continuity test thru O-Blu regardless of the position of the cam and with the blade contacts not touching. R-O does make/break as the Cam rotates. The schematic says #1D O-Blu is the only switch normally closed(pic). I was always of the understanding if a switch was open there should be no circuit, so I began to look for shorts somewhere. I've circled the switch in question and shown via an orange line how I think I am getting a positive test with both blades(O-Blu & Y) removed from the stack and alligator clipped. All other switches in line to Coin Setup Relay were found to be in the state shown on schematic.
This can't be right, or what's the point of #1D being a M-B if O-Blu is getting it's Y from another circuit?
Additionally, by virtue of what I see right below on schematic, is the Lock RE always on?
Thanks for the help.
Cam 1D circuit (resized).jpgmotor Cam 1.pdf
