So the game is now in the shop. I have done the following
All optos work that are highlighted in blue on the attached pic and I don't think this is a simple switch matrix wiring issue
Toned all associated wires from the CPU to the 16-opto board and from the 16-opto board to the trough connectors
Toned the column white/color wires from the 16-opto board to all switches on their respective columns
All test points on the power driver board read correctly
Opto boards and 16-opto board have 12v
Opto boards show glow in cell phone camera confirming they are getting power
Swapped the 16-opto board with a known working from a Champ pub
Removed all unnecessary connectors on the power driver to eliminate any possible issues
Prior to this coming in the following was done
CPU was replaced with Rottendog
Power driver was replaced with Rottendog
16-opto board was replaced with NOS
Trough boards was replaced with Anarchy trough boards
Previous to this failure and before the machine went on route the original CPU and power driver was rebuild by Coin-op cauldron so they should be legit.
