My Scared Stiff started acting up this evening. While flipping the right flipper the slingshot coil will fire. It is not happening on every flip, however, it is happening on the majority? Has anyone experienced this in the past?
Thx,
Andrew
Thx,
Andrew
Sounds like the slingshot needs adjustment, sensitivity is too high I guess. (had this problem once before)
Let me know if it helps when you adjust it.
The leaf switches that lean against the sling rubber need adjusted, make the gap larger, but not too much
What they said. It sounds like the pulse from the flipper is vibrating the leaf switch for the sling. It should just be a slight adjustment.
Turn the game off. Remove the slingshot plastic. Look down at the points that trigger the slingshot from ball hits.
Be sure they aren't all mangled, should be straight and clean.
Then the long front one should just be resting on the rubber ring. The rear one far enough away so vibration doesn't set it off, yet the slightest ball hit does.
A little adjusting and tweaking and you'll be a pro at adjusting them in no time.
LTG
I wasn't even thinking about vibration contacting the switch... My thought process was electrical... I feel like a dumb ass... Thank you all for pointing out what should have been obvious to me...
Quoted from wescor97:I wasn't even thinking about vibration contacting the switch... My thought process was electrical... I feel like a dumb ass... Thank you all for pointing out what should have been obvious to me...
Don't be so hard on yourself. We all had the learn somehow. Look at the positive--it was broken, and you fixed it.
This page was printed from https://pinside.com/pinball/forum/topic/scared-stiff-tech-issues-help and we tried optimising it for printing. Some page elements may have been deliberately hidden.
