With my Spider it will work and be spot on for maybe 5 or 6 games and then becomes tired, kinda stutter spins and is miss-aligned in regards to the award it is supposed to point to.
Motor, Opto?
Motor, Opto?
Clean the optos, and make sure the set screw that attaches the spider is securely attached. The spider should not spin freely without engaging the motor. This is probably your issue.
Did you run the Spider Test option in test mode? You should do this when the machine is "fresh", and at the point of having issues. This way you can see if the behavior is different.
This should point you to the correct fix, and be more clear if the motor has an issue.
First place I would check is the set screw on the spider pointer like T7 said. I have had the same issue with mine and that is what the problem turned out to be. I even put a little lock tight on it to prevent it from happening again. It is a 1/16 hex key screw , I think I had to remove the board from the back of the spider motor to get at it easier.... Good luck
This page was printed from https://pinside.com/pinball/forum/topic/scared-stiff-spider-trouble and we tried optimising it for printing. Some page elements may have been deliberately hidden.
