Hi just acquired a scared stiff. The right flipper was not working.
What I have done
Fuses were blown replaced these.
Tested Voltage on right flipper coil was 21v on all 3 tabs.
Tested tip36 q90 power driver and it was shorted.
Replaced Tip36 q90 and now when I turn the game on the right flipper is in the up (Hold) position. When i turn the power off after a few seconds the flipper lowers.
Suspected q92 Tip102 right flipper hold transistor. Showed shorted on 1 leg so I replaced it.
OK heres as far as I got. Flipper is no longer stuck up.
Voltage on right flipper coil tabs are now all 71 volts.
Right Flipper now works but not powerful like half power.
I detect it may be flipping on the low voltatge setting.
No more fuses being blown.
When in flipper test the power does nothing but the hold raises the flipper as normal.
Just to mention I unsoldered the wires to the right flipper coil and wired up the left flipper wires to it and it worked fine.
Could anyone please help me with this problem.
Thanks in advance.
Kindest regards David
