New! Dark mode!
(Topic ID: 255307)
Scared Stiff Power Problem (A\V board?)
By ElectricLou
10 months ago
  • 41 posts
  • 6 Pinsiders participating
  • Latest reply 10 months ago by PinballManiac40
There have been 22 images uploaded to this topic. (View topic image gallery).
2019-11-11 09_19_04-Scared Stiff Power Problem (A_V board_) _ Tech_ Modern games _ Pinside.com - Int (resized).png
2019-11-10 20_30_31-SCHEMATIC1 _ PAGE1 - 846ba2_99460d91ae4d41069a73f5fe1a6def76.pdf (resized).png
#1 10 months ago
Hi
I restaured a SS from scratch and now I have some problems with it..
When I power on the game:
1) Fuse F109 (12v unreg) burn
2) Only the backbox lights are ON
3) Led501 on AudioVisual board is dead.
4) Leds on CPU board are also dead
5) Leds on power board 100/101/102 (12v/5v/18v) are solid red and I have 0VDC
If I remove J606 from the AudioVisual board, the playfield lights up and the 3 Leds on CPU do what they should (solid, blinking, off). Speakers and ColorDMD are not working (Led501 is still dead on the AudioVisual board.
I took measurments on wires connecting at J605 on the AudioVisual board ( the board doesn't seem to get the right power).
I get:
1 =37V
2 =39V
3 =0
4 = 48V
5 = 3,64V
6 = 4,30V
7 = 6,65
8 = 9,30V
9 = key
10 = 17,60V
11 = 17,60V
From the manual, 1&2 should be 80VAC and 3&4 at 100VAC
What can burn F109 (12v unreg) and what shoud I do with my J605 power?
thank you very much!!
#2 10 months ago
Fuse F109 was burning because my ColorDMD power connector was upside down
still nothing happening
#3 10 months ago
Can you post pictures of the power driver board and A/V board with the wiring connected and the power turned on?
When did the problem start?
#4 10 months ago
Hi
Thank you for your Time!
The game was working great. I did a playfield swap, rebuild the cabinet, good cleaning of the boards, etc...I did a Vid1900 of myself
I think the game is a german reimport because the « power box » inside the cab was written in german and some wires have been cut. This hack was working good so I didnt touch it.
Let me know if you need anything else!
254E06B8-4541-43FF-9984-1CCF645FEBC5 (resized).jpeg9D4B9724-1E70-4871-A256-D4E708698817 (resized).jpegC21AC011-8DAA-4CDA-B69E-78B02C36053B (resized).jpegFF1DDCC8-081E-4540-984A-33EF28C2349B (resized).jpeg
#5 10 months ago
Currently, I see 2 LEDs out on your power driver board. Is that because the fuse is blown or the coin door is open?
#6 10 months ago
Quoted from PinballManiac40:
Coindoor is open
#7 10 months ago
Are they on with the door closed?
#8 10 months ago
All leds on Power board are ON when coindoor is close.
First led (100) is registering 12v and second one (101) 2.6v
Leds on CPU and A/V are still OFF.
#9 10 months ago
With power off, can you do a diode test on these 4 diodes? I think one may be shorted.
#10 10 months ago
All 4 are scoring 485 with black on cathode.
With red on cathode it goes between 800-900. It sometime starts with a bip from multimeter but it never goes to 0L
#11 10 months ago
Were those D19-D22? I don't have a board to look at. 12v gets converted to 5v in that area.
2019-11-10 20_30_31-SCHEMATIC1 PAGE1 - 846ba2_99460d91ae4d41069a73f5fe1a6def76.pdf (resized).png
#12 10 months ago
I have to go but I’ll let you know tmorrow morning! Your help is really appreciated!
Lou
#13 10 months ago
I would not be surprised if @zaza pops in with other suggestions.
#14 10 months ago
Try to boot without the 2 ribboncables on top of the cpu board and do connect J606 and see what happens.
The led on the av-board is not a power LED
#15 10 months ago
Quoted from zaza:
Very interesting!! I never really paid attentioned to that LED, nor have I looked on the schematic for its function.
#16 10 months ago
Quoted from zaza:
My understanding (and experience from diagnostics and repair) is that the LED is an indicator of AV ASIC functionality.
#17 10 months ago
Great to have a dedicated team on my problem! @zaza is one of the best assets of this forum. Thanks!
These are the same you asked before
Quoted from zaza:
Nothing different
FYI I added the leds meaning from the manual.
3DBEFAC8-C3A8-4EB3-9975-2D478CF0DB2B (resized).jpeg5DF0AAF8-C988-4A3C-96B9-749446068A65 (resized).jpegF7BD45BC-9D89-4698-A6CD-032C4F5A8886 (resized).png
#18 10 months ago
Is it normal to get these voltages in A/V board J-605 from transformer secondary?
I measure way less than the manual..
54D69F45-39C2-4D0F-A7CA-CBE3BF1BB4FF (resized).jpegB6DB1C3D-7F38-499F-B494-29903A9DDBFF (resized).jpeg
#19 10 months ago
Quoted from ElectricLou:
Nothing different
If the cpu still doesn't boot without J201/J102, it seems that the av-board is pulling the 5 volt down.
Inspect the av-board closely, especially soundROM S2, difficult to see on my little screen but it looks wrong orientared. If so, it is likely blown now.
About the Vac measurments, you don't measure Vac from GND to live. And be careful there, this is high voltage
#20 10 months ago
Not sure what side S2 should be but it wasn’t on the same side as S3&S4...
I switch side but nothing different.
Does it mean the soundrom is blown and with a new one the problem might get solve?
#21 10 months ago
Quoted from zaza:
Wow! Didn't see that one either! Sweet catch!
#22 10 months ago
I measure way less than the manual..[quoted image][quoted image]
It seems you are testing AC against the backbox ground. Correct way to measure those AC voltages is to measure along the hot and return for each pair of transformer windings.
ex. You have to measure VAC on pins 1 and 2 to test 80VAC and measure 3 and 4 to test 100VAC.
2019-11-11 09_19_04-Scared Stiff Power Problem (A_V board_) Tech_ Modern games Pinside.com - Int (resized).png
#23 10 months ago
What do you think zaza ?
I should buy a new soundROM and we’ll see?
Last question: does it matter which way you solder pop bumper flasher under PF?
Since I can test lamps and flashers when I unplug J606 from A/V board and by closing the coindoor, everything looks fine exept the 3 pop bumper flasher.
When I test light leads under PF with a battery, it lights no matter the polarity I try. Does it mean it’s the samething when I solder the wire on the light? I wish I could be clearer
#24 10 months ago
Turn it around and give it a try. Be nice to see if the game will boot correctly, but your sounds may be dead. On occasion, get lucky.
#25 10 months ago
No success
Thanks for your input
#26 10 months ago
No success
No boot or no sound? Try removing the part that was in backwards. For sure no sounds if it is removed. Just mainly interested to see if you can get the game booting again, even if it is without sound.
#27 10 months ago
Samething with or without de SoundRom.
No Images on DMD
No sounds
No lights on PF
Only things working are those connected on the power board or coindoor board: underlight cab, flipper buttons, colle DMD, speaker lights, eyes on the boney beast.
It looks like the A/V board is not working
129F84DB-E339-4B85-9B6A-83F45D6322AE (resized).jpeg9A8BA3E3-83A1-4130-8250-88D365B18A7B (resized).jpeg
#28 10 months ago
Don't know. You already tried to boot without S2-ROM and still had no cpu-boot so I think someting is very wrong with av-board.
Final test would be to to pull all eproms fron av-board and see if it will at least boot with display.
If the sockets are wedge it doesn't matter. Some LED flashers are polarity sensitive but that would only be problem for bajonet socket.
#29 10 months ago
Just confirming: that AV board worked prior to your restoration?
#30 10 months ago
Quoted from pintechev:
Yes. 100%
electronic is not my strong suit so I only cleaned boards and labeled connectors carefully. Nothing has been add or remove after resto.
Nothing different when I remove all roms. DMD is still powered but no signal.
Like I said first, when I remove J606 from A/V board everything comes alive exept for flashers/sound/colordmd signal.
I can’t test solenoids so I guess not
9899A91B-F639-4AAB-9AE7-7733DC47AE7A (resized).jpegE5B1BA1E-5595-4E6B-97E0-C9791709DA79 (resized).jpeg
#31 10 months ago
This board is very electrostatic sensitive.
Not working esd-safe can result in a not working board.
#32 10 months ago
I will find another board. I will let you know
Lou
#33 10 months ago
Rottendog does have a lifetime warranty on their boards. It is sounding like it has at least one issue. Trying another A/V board was about to be my next suggestion if you had one available so we know the MPU, driver and ColorDMD are good.
^^^ Since you found this, there is a chance the ColorDMD board was damaged. I think I recall someone else reporting that in another thread. Info@ColorDMD.com is their email. Maybe dmod will be able to tell us for sure.
#34 10 months ago
I will switch for another A/V board and see if it’s booting the CPU. If it’s working And the colorDmd is still dead, i will test with my old DMD
#35 10 months ago
Good morning!
This morning I put back the 3 Roms in the A/V Board and tried a last Time: power is on! Led501 on A/V board is solid red and CPU is powered.
Only the colorDMD and sound are not working.
I read that Led501 should be blinking...at least it's a start!
I know the colordmd is not fried because I can access its menues. But it shows only a white screen.
For the sound, all connections are straight foward and nothing happens. Not even the boot sound.
WoW. Progress! I might have plugged the ROMs incorrectly at first.
I Guess my next step is to try another S2 ROM ( the one I previously plugged backward)?
What can cause the color DMD failure? Another ROM fried? Something else on the A/B?
02F74834-54D4-418E-9274-D4C219159747 (resized).jpegFB2BE95F-2959-482A-95A5-41470CA00BAC (resized).jpeg
#36 10 months ago
Did you find another A/V board yet to test with?
Close up of the ColorDMD board please. Mentioned before, applying power backwards likely damaged something beyond the menu.
#37 10 months ago
Not yet...
#38 10 months ago
I would try testing with the original DMD just in case.
#39 10 months ago
Quoted from Phantasize:
I can’t find the DMD orignal cable. Damn it!
#40 10 months ago
Hello
I changed the A/V board and everything’s fine now!
Thanks for your help! I Learn everyday!
Lou
#41 10 months ago
Time to send the Rottendog board back to them for their warranty repair. They are good about fixing boards, even though a power cable was plugged in backwards.
6,600 (Firm)
Las Vegas, NV
6,300
Mt Zion, IL
