Couple routes....remove mylar, touchup and then either mylar again to have pf cleared, I think there is someone that makes that decal so you would have to remove the mylar and apply or buy a new pf and complete a swap.
just put a mylar for the meanwhile so it doesnt wear/tear any worse.. but I would think it has to be painted and cleared to be repaired
Gotcha! So I could just remove the mylar, touch up paint the small wear spot, and then put mylar back...correct?
I think they make a decal to fix this problem. Check pinballdecals.com or on eBay for a decal sheet. You may have to buy a whole sheet of decal for every insert. Easier fix is to touch up and then put clear coat over that spot and then I would put a piece of Mylar of the clear
If I remember correctly that whole area is mylar from the factory or it was on the two I owned. You would be best off taking all the mylar up and touching it up then applying new mylar to preserve your touch up and look factory
Just ordered a bunch o' stuff from Marco.
What type of LED's do I need for the backglass lights? hmmmm?
Cool white super brights probably the best bet. Maybe some warm superbrights since there are more warn colors in that translight. Maybe some color ones to match the targets in the spinner/backbox game
Hey there! Thanks. What is the bulb number? There seem to be more than one kind of bulb back there. I'd probably keep them all white as there is so much color in the translite. Warm superbrights sound good....
Quoted from spfxted:Gotcha! So I could just remove the mylar, touch up paint the small wear spot, and then put mylar back...correct?
Careful removing that mylar, if you do. Doing so can lift up the artwork. Search for mylar removal posts.
Not sure on scared stIff bulbs. Probablyb44/47's. Unless its a wpc95 game then they are 555's. Bigger bulbs are flashers. I can help you remove the Mylar when we get this trip set ip
Quoted from smokedog:Marco carries it:
http://www.marcospecialties.com/pinball-parts/CA-9C
Marco just cancelled my order! They no longer have the Terrifying Mylar!...and don't know where to get it. Any other places??
Ebay has this auction:
ebay.com link: SCARED STIFF Pinball Insert Decals LICENSED
Other than that, I don't know.
Jeff R.
This page was printed from https://pinside.com/pinball/forum/topic/scared-stiff-playfieldhow-do-i-fix-this and we tried optimising it for printing. Some page elements may have been deliberately hidden.
