Hello Pinsiders!
I just got my self a Scared Stiff pinball machine and new to this website.
Started a new topic in the restoration section because i noticed that the balls wont get pushed up from the hole next to the crate,
its also very annoying when you got the mini multiball from the crate you only recieve one ball because its censor does not see the ball.
What i did is remove the censor connector a blew air on the connections just to try,
and i noticed it worked for a couple of minutes but now is back to not working again.
The ball will only get out of the hole when there is no ball on the playing field then after the ball searching,
he spits out the ball from the hole.
Well hope i could get some help on this mather.
And also miss that little steel blocker next to the spider hole (one direction) what is that part called?
Thanks for now.
Cheers,
Stefan
