Hi there,
I have recently bought a Scared Stiff running the 1.4 rom. It is working well besides one small glitch and looking online I haven't seen any other discussion of it happening so I was hoping someone here may be able to help me.
When 2 balls have been locked in the coffin already, but the lock is NOT lit for the third ball to be captured, if you shoot the ball up the left orbit (where the lock would be) it will play the animation, lights, and sounds as if you have activated the "Stiff in the Coffin" mode. Usually the ball goes into the skill shot hole or spider hole after this shot and it holds it there until the animation has finished. Then the game resumes as normal. This will happen as many times as you make that orbit shot while 2 balls are locked already and the third lock is not yet lit.
The diagnostics report that all as is it should be but this is my first pinball machine so I haven't tried anything else to fix it. I'd appreciate any advice on things to check.
I notice that the 1.5 rom lists one of its improvements as "Improved Coffin Multiball display effect" but that doesn't really sound like it is dealing with the problem I am having.
Thanks in advance for any help you guys can provide.
