Need some help with Scared Stiff flipper buttons not responding:
My flipper buttons were unresponsive so I replaced the opto boards. I received the flipper opto boards from bigdaddy (very nicely made btw) and installed them, however my flippers still don't work. With the new boards installed, neither flipper button registers on the switch test. Both flipper coils actuate just fine however from the test menu so I know the coils are fine. It acts like both flipper buttons are completely disconnected however I double checked the wiring connector and it's correctly and firmly seated on each opto board (they only go on one way anyhow). I also checked the opto interrupter and it looks perfectly aligned on both optos and clears the opto when the button is pressed. I can't imagine there is anything wrong with the new boards, I am wondering what I should be checking next. I have uploaded some pictures including pictures of the optos and the board they connect to in the lower front of the cabinet. Thanks in advance for any help from someone smarter then me
Casey
