(Topic ID: 327806)
Scared Stiff Coin Door Lights and Hackery
By mal7887
3 months ago
  • 10 posts
  • 4 Pinsiders participating
  • Latest reply 3 months ago by zaza
#1 3 months ago
Greetings All,
I've had a scared stiff for a few years and the coin door lights have never worked. I finally got around to messing with it today. According to the manual power is supplied from J110, I am measuring 7.42v AC on Pin 1 (white) and 5.4v AC on Pin 3 (purple). There is a hack directly adjacent to the J110 connector that was there when I bought it, that I have not ever looked into or messed with.
Can someone help me make sense of what I am looking at here? The diodes have all been cut out and 4 Jumper wires have been installed. There are also some very obvious burn marks. D30 would also go to J110 Pin 3, which goes to coin door. Is this hack a potential part of the problem?
First two photos are of the hack in question, 3rd photo is of MM for comparison.
Thanks,
Matt
#2 3 months ago
Quoted from mal7887:
Not a hack it's a service bulletin recommendation.
Measure voltage at your coin door lamp sockets and trace back from there.
#3 3 months ago
install a wire like this and you're good
#4 3 months ago
Quoted from slochar:
Good to know
I am only getting 2.25v at the sockets on the door. Same at connector going into coin door interface board. Guessing there is a break in the wire somewhere or bad connection at the harness plug. I'll see if I can trace back to figure out where.
Thanks for the response.
#5 3 months ago
Quoted from zaza:
Does this need to be done? I don't want to fix something that isn't broken. This machine is 100% LEDs.
#6 3 months ago
Yes, if the jumpers were installed correct (like below), it would have worked. Now it is only a reinforcement of the traces and GI#5 is not powered.
#7 3 months ago
I would take any advice given by zaza and do it.
I am not sure how you are measuring VAC. VAC is usually measured from point to point and not point to reference. For WPC GI, one side of the GI is tied to ground (reference). Measure the GRN string for a control. Both the GRN and VIO strings on WPC-95 are always on (not software controlled).
#8 3 months ago
Quoted from zaza:
Made the changes to board as you suggested and it's fixed now.
Thank you for your help.
Trivial issue I know, but it always bugged me that these didn't work.
#9 3 months ago
Quoted from DumbAss:
You are correct that I was not measuring point to point. Noted for future troubleshooting
#10 3 months ago
it's fixed now.
Well done.
I assume there is also more light in the backbox, behind the translite
£ 38.00
PinballToys
Led
$ 54.99
Shooter rods
$ 299.95
Pin Stadium Pinball Mods
Led
Men
This page was printed from https://pinside.com/pinball/forum/topic/scared-stiff-coin-door-lights-and-hackery and we tried optimising it for printing. Some page elements may have been deliberately hidden.
