(Topic ID: 29319)
SCARED STIFF Club...Members Only
By spfxted
9 years ago
  • 3,941 posts
  • 424 Pinsiders participating
  • Latest reply 2 days ago by Pinkitten
  • Topic is favorited by 153 Pinsiders
There are 3,941 posts in this topic. You are on page 76 of 79.
#3751 1 year ago
Quoted from Lethal_Inc:
Anybody know where to get the blue plasma disk mod by chance? I see battery operated ones but not ideal for a pinball machine.
Mezel mods has the monster bash one
Lighted pinball mods has the plasma bumper cap mod
#3752 1 year ago
I think the Mezel mods one only works on the MB SE, that’s what it states anyway. Judge Dredd pinball on eBay use to sell them but don’t see them anymore. Those pop bumper caps are pretty cool but too pricey. Damn.
#3753 1 year ago
All 4 of my 5v (lg base) flashers on back board not working, any thoughts? Fuses are fine and no other flasher issues. Just that one circuit.
#3754 1 year ago
I have some spare parts I’m looking to sell. Have 2 coffin popper weldments, one brand new ($75 shipped) and one used that is slightly bent at the coffin lockout but has the coffin decal ($45 shipped). It worked fine before taking out, just wanted a perfect coffin. Also have a set of painted lane guides ($16 shipped).
09EBA91E-C9B0-48DD-A392-1D8FC5CB3ECA (resized).jpeg1F33C6FA-113F-484A-895B-DAB8F90D5898 (resized).jpeg1FA9D5BD-272A-4629-B6FC-C1968403DD2F (resized).jpeg509F526A-5ECC-4A7D-B5E4-7E64FE51739F (resized).jpeg5E143C40-5508-4245-A653-7471DC6EB388 (resized).jpeg9FE333A7-F118-4193-963C-E95C14A47735 (resized).jpegD996D611-C7EA-4B4B-B7E6-AAEC910C7298 (resized).jpeg
#3755 1 year ago
Might you have an extra set of left entry ramp brackets (couldn’t find proper term listed in manual)
60036CE9-6600-483B-8463-C2931F967578 (resized).jpeg6559DBFE-26FF-42AA-8527-36B8C837DC4B (resized).jpeg
#3756 1 year ago
[quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image]
PM sent for the guides
#3757 11 months ago
go into light test, middle gi's are dim for some reason. Upper and lower are all fine. checked plugs on boards, can't find any broken wires or loose connections anybody seen this before.... they work just dim.
#3758 11 months ago
Have you checked the voltage at the GI header and then again at one of bulb bases? Could be a voltage drop causing the issue. If you find it at the board, unplug the load and see-if it changes. Also could be a bad ground.
#3759 11 months ago
Ball Saves. Feature Adjustments 8: A.2 08. I set it to OFF and I still get ball saves. The OFF setting is retained, but it still gives me ball saves.
Does U9 Presets/ Game Difficulty override A.2 08? I am on MEDIUM which defaults to ball saves, but I figure A.2 08 should have precedence.
Software 1.5
I don't like losing a ball off the plunger, but I don't need Elvira's pity. Any ideas would be helpful, I am probably missing something simple.
#3760 11 months ago
Any tips or suggestions on removing both ramps to clean and get access to the lamps? Also, does anybody know for certain what type of lamp sockets are under the ramp entrances so I can order the right LED lamps? Probably go with warm white in both.
EDIT: Never mind. Found thread which described this exact issue.
#3761 11 months ago
Lethal_Inc WackyBrakke has just removed the ramps from his SS this week. Reach out to him, I’m sure he can send you some photos of the areas you need.
#3762 11 months ago
Anybody know why no body carries the leaper frog target switches, part # A-20783-7? Has this switch been discontinued? Also saw on the Pinball Center website that Part # A-16816-7 which is a standup target switch black, small (rear mount) that the mount can be changed to be used on Scared Stiff. Is this correct? Marco carries the A-16816-7 switch and it looks like the mounting bracket can be switched to either the front or the back.
#3763 11 months ago
I'm about to acquire a used SS. What (specific to this game) should I check for?
#3764 11 months ago
Make sure the light under the left ramp works. (and better if it's an LED)
#3765 11 months ago
Quoted from chaz009:
I would say the trickiest past is the spider hole kickout. Verify it launches the ball reliably up onto the bone beast ramp. Also, check the ramp itself above the spider hole isn't cracked.
#3766 11 months ago
Make sure the diverter works and the spider motor control board too.
#3767 11 months ago
Anyone know where to get the leaper switches or if the ones above would work if you can change the mount.
#3768 11 months ago
EDIT: Wrong thread
#3769 11 months ago
Quoted from ThatOneDude:
So, the teardown begins.
Someone sort of fixed the right mist ball gate. It doesn't open all the way, so the mist multiball fails. I need to replace it.
Did you mean for this to be in the BSD thread?
#3770 11 months ago
Quoted from hAbO:
*sigh* Yup, I did. It's been that kind of morning.
#3771 10 months ago
Ok, How can I paint these to look better?
#3772 10 months ago
I used a paint marker. Fill it in then quickly take a rag and wipe off the excess. Turns out pretty good. Good enough for me anyway...
#3773 10 months ago
I does look good. Doing it! Thanks!
#3774 10 months ago
Quoted from Gorgar666:
I used a stain my buddy had laying around. Same idea, rub it on then wipe off the excess. I did a light spray of rattle can clear as well.
#3775 10 months ago
What color is the marker you used?
#3776 10 months ago
So I’ve acquired my SS and I’m having an issue with a plunging. If I shoot as hard as I can I’m lucky if I make it to the spider hole.
My immediate thought was the shooting rod was Weak due to the gap between the rod and the ball (see pic). In my limited experience with pinball machine repairs, my first attempt was to extend the rod by mover the rubber on the rod up. It did very little to nothing.
I contacted the seller and he immediately said to check the auto plunger. And when I did, I noticed a screw holding the auto plunger forward (see pic). I’d like to try to take that screw out but since the screw has slightly cracked the wood I’d be very worried about screwing it back in if needed.
I also took a slow mo video to see if the ball is bouncing back and forth while traveling up the the lane and it did not appear to be the case.
I’m looking for advice if I should try taking the screw out or is there some way I can easily extend the shooting rod? The game seems to auto plunge very well as is.
Any help would be much appreciated.
4269AB93-6B79-47B2-85DE-B56707F35A38 (resized).jpegE0EE1D8C-E3A3-4CED-9CEF-0BB53E3781EF (resized).jpeg
#3777 10 months ago
1. Your autoplunger is out too far due to the screw. This causing the shooter rod to contact the ball very late in it's travel causing weak plunges. 2. Only one tang of the autoplunger is contacting the ball. Both tangs need to contact the ball. What probably happend here is the autoplunger was not plunging well due to the contact issue so someone put the screw in there to make the auto plunge stronger defeating the shooter rod plunge. Take the screw out and bend the tang on the auto plunger so both tangs contact.
#3778 10 months ago
Quoted from Tablewicked:
Looks good. Wish me luck!
#3779 10 months ago
Quoted from whthrs166:
I really appreciate the advice.
Are “tangs” the two forks at the end of the auto plunger (the metal that makes contact with the ball)?
#3780 10 months ago
Black
#3781 10 months ago
Does anybody have an extra boney beast rib? I have one that busted when I was opening it wider to go over the ramp sides. All I need is one. Thanks.
#3782 10 months ago
Anybody have an extra boney beast rib? All I need is one.
So you want to purchase just one rib? Maybe you should check with Chris Rock.
#3783 10 months ago
Ha ha. Funny. Yes, how much for 1 rib?
#3784 10 months ago
Joined the club. Added 1.5 code, speaker lights, inside decals, need to get color dmd . Has a red one now. Opened out lanes up.
10A57CB3-F122-4E5C-BA7B-1DFE012E4D63 (resized).jpeg318D34F9-DF90-4A4B-9DBE-3DDF888321A5 (resized).jpeg47D08175-23A8-4F1D-83E9-E0296AE52C32 (resized).jpeg6BDE47F0-0095-4FF6-A217-D2DDE0545175 (resized).jpegA14B26B4-5FE1-4CD4-A843-29296233C6DF (resized).jpegB5DD5FAB-AC87-468E-BBF4-947F97FA52E6 (resized).jpegC537FA30-63BA-48A0-8387-D056CF3676F9 (resized).jpeg
#3785 10 months ago
I have extra ribs pm me
#3786 10 months ago
Quoted from tatman9999:
Congrats on your SS! Looks like you found a nice one. It looks great in your classic 90s pin lineup, and it deserves a spot there. Such a fantastic game. It will look great with a color DMD too!
#3787 10 months ago
Update to my post: I removed the screw (Pictured above) and the plunger is very strong now. I believe the previous person put a stronger spring to compensate for the ball be far away from the ball.
My new minor problem is that the shooting rod catches the auto plunger slightly. Not sure how I can adjust this? Everything seems to work fine otherwise, should I really even worry about it?
#3788 10 months ago
Quoted from littlecammi:
For those of you who didn't get the joke...
#3789 10 months ago
I adjusted the shooter rod on a SS. I don't think I had to play with the auto plunger in that case. I just loosened up the mount screws and centered it. I don't recall doing anything else, but it's been a while.
#3790 10 months ago
I am looking for someone that has installed the light up coffin decal. Where does it connect to? The installation instructions with the decal are not clear. Also I removed the coffin lid to replace it. There is a tiny spring under it. I did not notice how that spring is positioned when reinstalled. If someone has a chance to look under the coffin lid at the spring would you please try to describe or get a picture of which way it goes?
#3791 10 months ago
I recently picked up a scared stiff and found a pretty nice one. Only problem I am having is the spider does not stop where it is supposed to. Is there an easy way to adjust it? Or a hard way for that matter?
#3792 10 months ago
Does it stop at all when the flippers are pushed? Where does the spider point when the game is first started? The spider stopping on mine is a bit of a timing issue. It kind of drifts maybe 2 items before it stops once the flippers are pushed. What exactly is yours doing?
#3793 10 months ago
It’s stopped at about 630 on a clock when I start a game. It does stop when I press the flippers just not in the right
#3794 10 months ago
Quoted from PittPin:
As far as I can tell, that is normal. On every game I've ever played with a working spider, you time it a little less than 2 items ahead, mine included.
Now, mine will occasionally hang, kill the current spider spin without an award and switch to the lights. It comes back online if you just shut down the machine for a bit. I suspect the stepper motor is gunked up and needs to be replaced or disassembled. It could also be a cold joint on the connector. I'll deal with that when I do the cab and playfield swap.
Quoted from Don44:
Does it award you the right thing when it stops? For example, if you manage to stop it on the crate, does it award the crate?
I would pull the spider arrow off of the stepper and look at the diverter. Is it broken and not blocking the optos? If it is, are the optos working? Could you have a flaky opto board or connector? Check the solder job and see if you have a cold joint. There is an aftermarket board and stepper available.
#3795 10 months ago
Have tried running "wheel Test" T.16? The problem is isn't doesn't say much about what makes the test pass or fail. I had trouble with mine and found several threads dealing with the spider circuit and the motor. I'll see if I can locate them and point you to them. I have a long write-up that I saved that explains how this thing works. I'll try to pm it to you or maybe I'll need email to attach the file.
#3797 10 months ago
Make sure the bolt that mounts the spider to the motor shaft is tight or It can slip and not stop a the correct location. Be very careful as can easily be stripped
#3798 10 months ago
If you need to replace the motor here is what I used and it worked perfectly ($15)
https://www.sparkfun.com/search/results?term=9238
#3799 10 months ago
Shouldn't the home position of the spider pointer be at 1 o'clock?
#3800 10 months ago
It does not give me the award its pointing at but the one that lites up.
