(Topic ID: 29319)
SCARED STIFF Club...Members Only
By spfxted
6 years ago
  • 3,407 posts
  • 362 Pinsiders participating
  • Latest reply 6 hours ago by spfxted
  • Topic is favorited by 118 Pinsiders
There have been 1,162 images uploaded to this topic. (View topic image gallery).
There are 3407 posts in this topic. You are on page 58 of 69.
#2851 1 year ago
Quoted from hAbO:
Has anyone removed/replaced the inner backboard or backglass detail? I have one however I never installed it. Just wondering how difficult it is because it seems like its a decal with adhesive.
Yes and it is not nice to change. There is no special talent needed, just a lot of patients. Getting the old one off is the worst of it.
#2852 1 year ago
Quoted from spfxted:
Oh, I didn't hear that. I only heard she won't appear in costume anymore. I'll find out....
I most likely misheard things.That's probably what it is, no more dress up. If she comes to Chiller, I'll definitely be heading up there. I'd love to have her sign a few pieces of pinball art.
#2853 1 year ago
Quoted from Honch:
I'll let you know...and come up as my guest!
#2854 1 year ago
Thanks, that would be great.
#2855 1 year ago
Quoted from whthrs166:
That's what I was scared to hear I wonder if the freeze method would work or the opposite - heat gun on a low setting.
#2856 1 year ago
Quoted from hAbO:
I did use the hairdryer but it comes off bit by bit. What stinks about it is that the new one is glue on instead of a sticker. I think you just have to lump it and take your time.
#2857 1 year ago
Don't they have new ones available?
#2858 1 year ago
I have only seen the glue on ones.
#2859 1 year ago
I'm hoping for a bit of expertise to tackle an issue with the balls not always ejecting properly from the coffin. Weirdly enough, the problem only seems to be with the last ball and occurs either when I get the 3 lock multiball or the machine is trying to clear multiple balls from the coffin after the game has ended. The ball shoots up but doesn't usually make it out of the coffin...its close though. The first few balls have no issue. I found the following service bulletin and was curious if anyone has encountered this issue and how they've fixed it. Would love a pic or two as that is always really helpful. Here's the service bulletin:
"If the game clears multiple balls but has trouble with the last ball, the eject plunger and coil need to be aligned with the tube leading upwards in to the coffin, most often this is solved by adding a thin washer between the top coil mounting bracket part# 01-9794 and the popper assy. weldment part# 04-10349, alternately the washer can be added to the lower coil mounting bracket to move the plunger the other direction if necessary"
Thanks in advance for your help!
#2860 1 year ago
After someone helps per3per3.........I just want to thank Bob for installing a color DMD in my Scared Stiff an hour ago! Looks great!
#2861 1 year ago
Quoted from per3per3:
Tech help bump
#2862 1 year ago
Help him bump
#2863 1 year ago
did you attempt the bulletin and it didn't help or are you asking if anyone else has tried it to remedy the same issue?
#2864 1 year ago
Quoted from weaverj:
I haven't attempted the bulletin's solution and wanted to see if anyone else has or if they implemented something different.
#2865 1 year ago
I have done this but not to my SS. It’s a plunger to ball alignment issue. It will move the plunger to hit the ball so it will come out of the VUK smoothly
Take the glass off, set the test mode for the coffin vuk to operate toss a ball in and see how it is kicking it out then throw all three in the lock and watch them come out. Once you get the plunger aligned right the problem will disappear.
#2866 1 year ago
LCD or LED? I did the LCD years ago and I still marvel at how nice it looks
#2867 1 year ago
Really appreciate the advice. It's strange that the issues only impacts the last ball when multiple are ejected from the coffin. You'd think an alignment issue would impact any ball ejected from the coffin.
I'll get some small washers and implement the fix.
#2868 1 year ago
Oh, I don't know! It was the $400 one, if that helps. It looks great! lol...I've already lost balls because I'm watching the damn color display!
#2869 1 year ago
Then it's doin it's job!
#2870 1 year ago
How did you go about getting the plunger properly aligned?
#2871 1 year ago
Hehehe...
#2873 1 year ago
lol.
#2874 1 year ago
Man... they're gonna smudge up the glass.
#2875 1 year ago
Well, I think that those guys could probably handle that task.
#2876 1 year ago
You have to shim the coil mount bracket with washers for the coffin vuk.
#2877 1 year ago
She said Tale of the 'Bony Breast ... Beast' to me last night...then I gave her multiple jackpots She always brings a smile to my face.
#2878 1 year ago
I actually shimmeed the two left most screws for the whole mech and the fix seems to be working. It's not the fix the service bulletin suggests, but it accomplishes the same thing and it works! The power of gravity for the win!
#2879 1 year ago
that was last year at allentown ?
#2880 1 year ago
Hi guys,
New to the SS club, bough it on site, regular condition, missing parts but willing to restore her to shine again!!
Gustavo
#2881 1 year ago
Looks good, hope it was priced right for ya. Good luck with her.
#2882 1 year ago
Hi, price was right $1.250, it's working but needs some parts and cleaning, cabinet and playfield in good condition fortunately.
Gustavo
#2883 1 year ago
Quoted from Haggy38:
Gustavo
WOW congrats! Can't go wrong there....
#2884 1 year ago
Thanks, Im very lucky!!
Gustavo
#2885 1 year ago
Gustavo
That is a bargain
#2887 1 year ago
Thanks guys,
Fortunately in Colombia there's not a high pinball demand, that helps. I need help here, the playfield is missing the skull pile, Marcos got it but it seems there's a leds board behind them? A picture would help. Thanks
Gustavo
#2888 1 year ago
Congrats on the buy! I lived in Colombia for 4 years in the 60's. We started at Barranquilla, then Medellin and finally Cali. Only went to Bogota once.
#2889 1 year ago
That's great, Colombia is trying to change its brutal past, Bogota, Medellín and Cali are great city's now, lets don't forget Colombian beautiful girls jejejeje. More than welcome.
Gustavo
#2890 1 year ago
Thanks guys,
Gustavo
There isn't a board. It is a cable harness with LEDs installed. Same story with the candle flames. You can buy it here:
http://www.pinballdecals.com/PartsByGamePages/SS_Page.html
Does the area have the flashers installed? You might need that also.
#2891 1 year ago
Quoted from Mad_Dog_Coin_Op:
Thanks,
This is what I found....
#2892 1 year ago
That is funny. See that hole with nothing in it closer to the back side of the Boney Beast. That is where red flasher goes. Please see photo:
The remaining holes is where the flasher should be that backlights the skull pile. I don't think the blue doom is part of the assembly.
#2893 1 year ago
So if you buy the skull pile, LED eyes and the candle flames you should be good to go. Just have to move a few things around.
#2894 1 year ago
Surprise surprise.... Welding on my future. Difficult to take apart from the playfield.
Gustavo
#2895 1 year ago
For what you paid for the game you could afford to make plenty of repairs...
#2896 1 year ago
I need a little bit of help. I got powdercoated siderails for my machine. Can I install them with what I have around the house? Someone said I may need a heat gun (or hairdryer?) to remove the old rails? How are they held on? What do I need to put on the new ones? screws? Double sided tape?
If someone has detailed instructions I'd appreciate it.....
#2897 1 year ago
I use a thin scraper under the rail right next to the nail to lift it slightly. Then, I use a pair of vice grips with a sharp set of teeth at the very end, and work them under the lip of the nail. The vice grips I use are Irwin brand. They look something like this: http://www.irwin.com/tools/locking-tools/fast-release-long-nose-locking-pliers-with-wire-cutter
I looked through everything they had at Lowes to find a set where the teeth are exactly at the end of the jaw. Worked like a charm.
More info
https://pinside.com/pinball/forum/topic/removing-side-rails-vids-guide
#2898 1 year ago
Thanks! So I really don't need to heat them up?
#2899 1 year ago
For a rail, I am not sure why. I've pulled a few, and they were only held on by the nails. I'd be curious to see if there was a difference.
#2900 1 year ago
Thanks Dude! So, all I need to do is pry that nail forward and pull it out. I already have other rails, so I'm not worried about these.
Pull old rails off after removing nails. Put new ones on and put nails back...or screws, etc. Got it!
$ 14.99
PinballElectronics.com
$ 54.00
