(Topic ID: 234671)
Scared Stiff Check opto trough 12v and wiring
By mpdpvdpin
1 year ago
  • 2 posts
  • 2 Pinsiders participating
  • Latest reply 10 months ago by hotwyl
#1 1 year ago
Hey all! Im having some difficulty resolving an issue with Scared Stiff. She started spitting multiple balls into play and when i reboot i get the “check opto trough, 12v and wiring” prompt
Here is what ive done so far:
ive reseated all connectors: nothing changed
ive had the mpu board and underplayfield opto board proffessionaly checked: no issue
ive replaced opto transmitter and reciever trough boards: problem persists
ive checked the wiring for breaks: i see nothing
More info:
all trough optos switches show filled in test with the exception of the ball jam opto
game will not start until i lift the playfield to trigger ball jam opto and then it proceeds to spit out all balls two or three times, subsides andthen a game begins. Typically first ball will run fine with no extra balls being thrown into play Ball two will start kicking balls out randomly.
I have the 12v daughter board installed to remedy the random shut down at stiff o meter completion. Led on board is showing a clean 12v
Am I missing something? This is driving me nuts.
Thanks in advance for any and all suggestions!
- matt
2 months later
#2 10 months ago
I am having the exact same issues with mine, hopefully some one will chime in that may have had the same problem that can offer some advice.
£ 49.00
PinballToys
£ 49.00
PinballToys
$ 399.95
Pin Stadium Pinball LEDs
PinWoofer
