Good morning,
Not sure if this is the correct channel for this, please move if needs be
I recently managed to get hold of a Scanjet 4600. Installed the 64b driver, it's working fine under Win10
I would welcome some recommendation to use it for playfield scanning, specificall:
- Speed... With the Win10 default app, starting a scan takes forever... At least 30s before actually starting even to scan something, if not more. When doing a playfield scan, this adds up. Is this expected ? Anyway I can cut down on scanning time ?
- Mechanics : is it really important to scan parallel to either axis, or will it be possible to stitch without too much concern ?
- Resolution : higher is better, at the expense of size... I would assume 600 DPI is sufficient in most cases ?
- Stitching: and finally... stitching... Anyone would have recommendations on a good stitching SW appropriate for playfield scanning ?
Cheers
