(Topic ID: 122705)
SC lamp problem (Video of problem added)
By twinmice
9 years ago
  • 70 posts
  • 12 Pinsiders participating
  • Latest reply 4 months ago by DumbAss
There are 70 posts in this topic. You are on page 1 of 2.
#1 9 years ago
I am having a problem with the individual lamps in the back box. In test it seems like they are one off what they should be, some are correct, but a few are off. In test it should be "dog" but the question mark is lit on the back box, then I check the next one which says "question mark" but the alarm 3 is lit? I resat the connectors, thinking maybe a diode problem but I don't see any individual diodes? Any info would be appreciated. Thanks
#2 9 years ago
Has it always been that way, or is this a new problem?
Have you removed the connectors in the lower right corner of the driver board?
Chris Hibler - CARGPB #31
http://www.Team-EM.com
http://www.PinWiki.com -The Place to go for Pinball Repair Info
#3 9 years ago
No just got it in a trade. Only resat the connectors on the lamp board and made sure the back box boards were pushed on.
#4 9 years ago
OK...so every controlled lamp in the backbox appears to be 1 off?
And, all of the backbox lamps will light at some time during test?
If it were a misplaced connector, then 1 out of every 8 lamps would fail to light. Probably 2 since the key pin would be involved.
Do the lamp matrix connectors look like they are still factory pinned? The lamp matrix connectors will have red wires and yellow wires in the connectors.
#5 9 years ago
Yes they are factory, boards are all original, some of the controlled lamps are correct some are not?
#6 9 years ago
The safecracker game backboard lights are a little weird and not a conventional switch matrix. only the playfield lamps are controlled by the lamp matrix.
There are 4 solenoid lines that are used as data lines (2 data, clock and enable) to drive some chips on the backboard light boards. and 3 of the GI strings are used as power.
The chips daisy chain the signals, so I think if one is missing or broken it might confuse the rest down the line.
I knew of one in Arizona that had the same issue (might be the same game) but I never had a chance to work on it to figure it out.
#7 9 years ago
So it could be a bad chip, I did see those on the lamp pcb, but unfortunately I can fix alot, but not to savy at chip repair.
#8 9 years ago
Is there an easy way to check them?
#9 9 years ago
no idea. How many lamps are wrong?
#10 9 years ago
Looks like a little more than half are off by one, and on a couple 2 lights will light in test, say I have teller in test and the question mark lights with it. That made me think possibly a diode, but it's not like a conventional lamp pcb.
#11 9 years ago
I just went through mine. Everything matches until I get to L47. L46, 45, 44,43,42,41 are all off. I would think this is a software problem. My machine has original untouched boards.
#12 9 years ago
Bad terminology ,they are not all off but what is displayed on the DMD does not match what is lit on the back box.
#13 9 years ago
Mine is running an older rom version 1.2, i ordered 1.8 today, maybe that will help, but i dont think its a rom issue, i read all the revisions since the 1.2 and there is no mention of a fix for this.
#14 9 years ago
unless you have the one from Arizona, counting generalgman's game and yours that is 3 SC with the exact same lamp issue. Got to believe it's a software problem.
#15 9 years ago
Ya not from Arizona, it be interesting to see what rom version the others ones are running.
#16 9 years ago
A YT video of the "issue" or "feature" would be nice.
#17 9 years ago
I'm running v 1.8. I can record a video of mine doing this.
#18 9 years ago
Vid would be great.
#19 9 years ago
I have heard of safecrackers having issues after the ICs on the backbox lamp insert get damaged. I don't think it's a software problem, as I've had 2 that worked perfectly.
#20 9 years ago
How can you check them?
#21 9 years ago
My backbox lamps work perfectly when it goes into the boardgame mode. You would think if the chip was damaged then you would have lamps lit in the wrong sequence when attempting to get into the vault. It is like the programmer missed the description of the insert.
#22 9 years ago
Mine are confused during the board game, and test, but are fine in attract mode?
#23 9 years ago
So when you are in the board game mode and you roll the dice for your moves, do the lamps sequence in the correct order towards the vault ? If you land on , say a bribe lamp, does the machine perform the correct action ( guard asks for money ?)
#24 9 years ago
No, if it lands on the bribe it gives me the next one like question mark, but only on about 70 percent of them.
#25 9 years ago
So, the game is from out of the country, i rewired the jumper, but thought i had read somewhere that the dip switches were all supposed to be one way, so i checked and they were not, thought this could be the problem, switched them all one way, but no change, still same problem, bummer.
#26 9 years ago
I will try and get some video today.
#27 9 years ago
Here are a couple small videos of the backbox lamp problem im having. Sorry the vids are not the greatest, i used my cell. Any help would be appreciated. Thanks Mike Paris
#28 9 years ago
Interesting problem.
Unfortunately, the copy of the schematic in the IPDB is really poor. I can't make out the part numbers.
If you can post a pic/scan of pages 3-21 and 3-22 in the manual, that would help.
The 48 lamp control board in the backbox connects to driver board connections:
J110 - special purpose lamp controller (used on AFM for the saucer chase lamps)
J138 - 12V power and ground
J106 - GI power
Transformer secondary - GI power
The board has 48 Darlington Transistors of some sort (I can't read the schematic) which are sequenced by an IC that might be a 4094 (again...can't read it) which is a shift register (which doesn't make sense so maybe it's not a 4094).
The board appears to operate more like a Gottlieb System 80 driver board or a Bally lamp driver board.
If someone can post good images of the manual's pages noted above, we can provide more info.
http://webpages.charternet/chibler/Pinball/index.htm
#29 9 years ago
Thanks Chris, hopefully someone can post a pic of the manual pages Chris needs, mine did not come with one and i have been using the online one also from IPDB.
#30 9 years ago
A shift register sounds right since the data coming in is only 4 lines and I think work like the LED's in the newest Sterns and JJP's pins.
Look on the parts pages of the manual and you can find the parts for the backbox light board (page 2-14)
U2-U7 are indeed 4094's
U1 is an lm339
Qi-Q48 are 2n6426 NPN Darlington transistors
#31 9 years ago
Here is the information from my manual. The schematic print is very small so I have taken numerous pictures close up so you can read the values.
image.jpgimage.jpg image-598.jpgimage-598.jpg image-544.jpgimage-544.jpg image-512.jpgimage-512.jpg image-506.jpgimage-506.jpg image-516.jpgimage-516.jpg image-716.jpgimage-716.jpg image-575.jpgimage-575.jpg image-869.jpgimage-869.jpg
#32 9 years ago
Thanks for the images.
I'll need to look at the function of a 4094, and how it's integrated into that lamp control system to see if the "one off" observation could be caused by a failure of this system.
#33 9 years ago
Now like I had said in one of my earlier posts that my back box lamps are all correct except for L42 through L48. If you look at the 4094, it looks like each IC controls 8 lamps in the board. I bet I have one damaged IC as well.
#34 9 years ago
Quoted from generalgman:
Sounds right.
You may be able to use the diode test, as outlined in the Wiki, to figure out which one is different and failed. Or we might be as to ID the one that controls those lamps via the schematics.
#35 9 years ago
So alot of mine are off, could all those chips go bad? I think only 8 are correct.
#36 9 years ago
Quoted from twinmice:
I think these work as a series, If one is missing or broken it moves all the other lamps ahead in the chain. So probably not all are bad in your machine, just an earlier output than the other posters in this thread.
#37 9 years ago
Had a friend send pics of the connectors to make sure the wires were correct and in order, thought maybe wired wrong from the factory, but they match, still trying to figure this out.
#38 9 years ago
The 4094 IC's that are on the back board are a CMOS Chip. These are easily damaged from static electricity. I'm wondering if these IC's get damaged from wiping down the plastic coin tubes with a cloth and the static generated getting transferred to the chips. The plastic coin tubes are very close to this board. I'm going to order some 4094's and will change out the one I think that is punched.
#39 9 years ago
Could it just be a bad diode? My D54 (one of the bigger ones) reads a little different than the others?
#40 9 years ago
So i got the latest rom today (1.8) and was hoping it would solve the problem since the old rom was 1.2, but did not. So i guess i will need to have someone come look at it that can hopefully figure it out.
#41 9 years ago
Generalgman, let me know when you change the 4094's and if they worked out for you. Thanks
#42 9 years ago
Still looking for any advice. Thanks
#43 9 years ago
You should haul the board out and conduct the diode test on each of the 4069 ICs.
If I had the board here in my shop, that's the very first thing I would do.
http://www.PinWik.com - The Place to go for Pinball Repair Info
#44 9 years ago
I would if i knew how. I know how to test diodes, but how do you test chips?
3 weeks later
#46 8 years ago
Ok, I have the same issue, board game out of sync, had the lamp board sent out & checked/tested, There wasn't really much wrong with it, all chips tested ok, repairer guy punched out old chips & fitted sockets, Anyway put board back in problem was fixed in one area but same issues popped up in other area, Lucky for me board had been socketed, Was advised to replace all 6 X 4094's & that has fixed the problem, old chips bench tested ok buy were flaky,
I'm very happy now, game works spot on, Thanks to the community here & especially Ken from AA
#47 8 years ago
Great news! Will have to do that.
#48 8 years ago
Let us know how you go
4 months later
#49 8 years ago
Does anyone know the value of these two resistors? The ones with the red ovals. I cant see from the manual, the print is to small. Thanks Mike
8,999 (Firm)
Montréal, QC
Richfield, MI
$ 95.00
Pinball Mod Co.
$ 54.99
KAHR.US Circuits
Nezzy's Pinball Prints
9,999 (OBO)
Royal Oak, MI
$ 1,059.00
$ 27.95
$ 85.00
Arcade Upkeep
$ 9.95
$ 109.95
PinSound
This page was printed from https://pinside.com/pinball/forum/topic/sc-lamp-problem and we tried optimising it for printing. Some page elements may have been deliberately hidden.
