Hi, everyone. I'm rebuilding a F2K and I'm at the point of replacing some connectors and caps on my SB-300 sound board. I need to replace J2 on the sound board because at some point before I bought it, someone replaced other connectors and routed the wires into basically a knot. Replacing J2 will help me undo that knot. Anyway, on J2, I was wondering why they would put two wires into pin 5? Pin 5 and 6 are shorted/soldered together. I'm assuming it's safe for me to put one of the wires in pin 5 and the other in pin 6? I understand why they did it on pins 2 and 3, they have 4 wires that both need to hit analog ground. I attached a pic for reference. J2 is bottom left. Pin 1 is on the right.
