On my Lucky Seven , the flippers look like this:
https://photos.app.goo.gl/YtfPka86Kv132JQn6
Is the active flipper supposed to be raised further up? It's almost horizontal, and it's difficult to cradle balls.
Thanks,
Tobias
Thanks,
Tobias
probably has the wrong coil stop in it. Or someone put a rubber bumper on the linkage side of the coil bracket.
Did you just get this?
It's probably all loose, with links worn out and in desperate need of a rebuild.
Wrong coil stop can do that too.
I'd replace the flipper mechs with modern units, much cheaper to service using common parts in the future.
Better EOS Switches, Better Coil Stop, Standard Coil Sleeve and no "bounce":
Quoted from vid1900:Did you just get this?
Yes, as in I have done nothing since I got the machine.
Sounds like everyone agrees, that my flippers are sagging and I should rebuild the flippers or upgrade them. What should the angle be when raised?
This page was printed from https://pinside.com/pinball/forum/topic/sagging-flippers and we tried optimising it for printing. Some page elements may have been deliberately hidden.
