Sorry if this has been asked before, but I could not find a specific discussion about this vintage of pins.
So I just want to make sure I am not going to taking the paint off of my playfield.
The 1951 Niagara I just picked up has a not so good "repair" on the playfield. It appears that a part of the playfield plywood delaminated and lifted up and/or a part of the playfield broke off, can't tell until I get into the "repair" more.
Someone tried to patch the area with what I almost positive is joint compound used for finishing drywall.
But they patched a 3" x 3" area, much larger than the damaged spot on the playfield. It is put on pretty thinly over most of that area and I can see through the joint compound and see the playfield paint underneith, which looks OK.
What solvents are safe for these Gottlieb playfields? I know that water will dissolve the joint compound right off(hot water is all I use to clean up my drywalling tools). But I am guessing that water is not the best choice for the playfield.
I was thinking of trying 91% isopropyl (rubbing) alcohol to start with, but I wanted to make sure that would not be a problem for this paint.
Hopefully someone has some experience with this vintage and manufactures paint and can tell me what will and will not harm the paint. Hopefully one of those solvents will soften/remove the joint compound.
Thanks for the help.
