(Topic ID: 203799)
Rusted staples and light sockets?
By PinballFever
6 years ago
  • 11 posts
  • 7 Pinsiders participating
  • Latest reply 6 years ago by wayner
    #1 6 years ago
    What would you do to clean these up? Remove and put in new staples or shine the staples and area up with a dremel brush? Shine up the light socket rusted areas with a dremel brush too?
    This is from drinks being spilled over the years on the backbox. Should there be concern about the rust seeping into the wood?
    Note: I want to preserve the original "patina" of this 60+ year old game as much as possible. I don't want to sand the wood like new but I am reluctantly willing to replace the light sockets and wire braid (is that what you call it?) if they need to be replaced. (Clay does explain how to fix the sockets by re-soldering the wire to the tip of the socket. Is this a viable solution here after cleaning the sockets first?)
    (Please let me know if this is the right place to ask this question?)
    Thanks,
    Bruce
    #2 6 years ago
    Bruce-I would use a wire brush in a dremel to clean up those sockets including the staples. If you do that delicately it should not change the patina of the wood. Only replace the sockets which have deteriorated to the point of not working although as you suggest per Clay you can direct solder to the pin if needed although I would prefer to replace. I also dremel brush the interior of the socket from the front. You would be able to obtain preowned sockets from pinjunk if you wanted patina integrity-Wayne.
    #3 6 years ago
    Doing what wayner suggests will work well (although polishing staples is something I never considered doing).
    I finish off the cleaning job on old light sockets by using DeOxit spray or brush on liquid. That will improve the longevity of the cleaning and the electrical connection.
    Alan
    #4 6 years ago
    There is a new product from China I posted a while back.
    Its a fibrous cylinder impregnated with rust removal agent that
    works amazing when activated with water.
    I use it for rust touchup removal all the time.
    It might help. Under $1.00 shipped.
    search rust removal stick on Ebay.
    (Not unwrap the binding outside yet to do the staples, I had very good results, except
    where rust was all that was left.)
    I use it on side rail rivets as well.
    #5 6 years ago
    Quoted from OLDPINGUY:
    Is your rust removal stick the stainless steel version?
    #6 6 years ago
    The product is advertised for Stainless Steel...as its the largest demographic to sell for pots and pans.
    Ive removed surface rust and light surface oxidation on stainless.
    Think of it as a rust remover, water activated on a brush.
    Its not going to worth to do all ones legs, but Ive touched up legs where needed, rivets, sockets, small rusted parts
    like screw heads, and bolts where I really didnt want to take everything apart, and an 80% improvement in minutes was good enough.
    For $1 delivered its worth a try, and just handy to have around.
    #7 6 years ago
    Quoted from wayner:
    Wayne-Which wire brush would you use for this? I think the brass brushes are softer than the steel wire brushes and I can stop by HF after work to buy some if need?
    Thanks,
    Bruce
    #8 6 years ago
    Brass, the steel may be to much.
    #9 6 years ago
    Interesting product. It looks like there would be some use for it. I don't think I would use it for the staples though, don't want the wood to get wet.
    Bruce
    #10 6 years ago
    I usually pry of the staples and clean the lite holders away from the backboard. Simple job to staple back down. While off I sand the backboard wood to clean up the surface. Sometimes I stop there and would on your game.
    #11 6 years ago
    Quoted from PinballFever:
    Thanks,
    Bruce
    Bruce-These are the brushes I use in my dremel to burnish metal parts. I obtain in lots of 25ea on ebay from China. Always wear safety glasses when using these brushes-Wayne
    This page was printed from https://pinside.com/pinball/forum/topic/rusted-staples-and-light-sockets and we tried optimising it for printing. Some page elements may have been deliberately hidden.
