Has anyone had an issue with the upper flipper stop working? The lower right is working fine but the upper one is dead? If so, what was the issue? Thanks!
Check it's fuse. Broken wire at the coil lugs. Check leaf blade switch for it on flipper button, be sure it closes.
I'd start there.
There are no fuses, they all come from the same node board 8, check the switch is ok first I guess then check the wiring at the coil
Quoted from ian866:There are no fuses, they all come from the same node board 8,
I didn't have a game to check. Thank you !
This page was printed from https://pinside.com/pinball/forum/topic/rush-premium-upper-flipper-issue and we tried optimising it for printing. Some page elements may have been deliberately hidden.
