Quoted from sepins:Thanks will go with Ninja. Is there an install video for them?
Yes, you'll get a QR code in your package, AND a link from Ninjacamp via Pinside.
I've got at least 150 plays on my Ninja, both scoop protector and scoop sleeves, and I love them. Can't imagine still having metal there. And Cliffy wants you to reuse the fork, which I just can't get on board with.
My stern just showed up.
Metal protector for each scoop and then the bracket with two black nubs.
Seems so weird they would turn that scoop into a harder to hit however, the right side of the scoop, with "mylar" on it has been dented pretty bad. I may end up going to the stern one while on route and then convert to ninja when the game is brought home.
Does anyone know if the Ninja and Mantis are compatible? Mantis for the inside, Ninja for topside?
I just ordered the Mantis, since they've been awesome in the past. Particularly for new games that don't need to cover up wear.
Got them too. Won't be using it on my personal game, Still thinking Ninja over everything, but the Mantis always seems to work well too. I just personally like the trimmed look of a protector that comes over the edge. I did order the Ninja when I saw them but have not installed anything yet. Deciding...
Quoted from northvibe:My stern just showed up.
No not bad - step by step slowly is the best way for me. I'm horrible at stuff like this and I did it in about 40 min.
Quoted from Hemispheres:Got them too. Won't be using it on my personal game, Still thinking Ninja over everything, but the Mantis always seems to work well too. I just personally like the trimmed look of a protector that comes over the edge. I did order the Ninja when I saw them but have not installed anything yet. Deciding...
Ninja is currently the way to go at this point, in my opinion. Great protection and looks great to boot. Been very happy with mine!
Quoted from Oiler2112:Ninja is currently the way to go at this point, in my opinion. Great protection and looks great to boot. Been very happy with mine!
Agreed. The Stern replacement I got in the mail looks terrible IMO. I suspect any metal protector they tried eventually got trashed.
I really hope Stern takes a look at what Ninjacamp has done here.
Quoted from Oiler2112:Ninja is currently the way to go at this point, in my opinion!
What is the website name if I want to order one?
Quoted from snaroff:Does anyone know if the Ninja and Mantis are compatible? Mantis for the inside, Ninja for topside?
Looks like several of us Pinsiders are in the same boat on this one. I have the Mantis, Ninja and Stern kits in hand.
Ideally, I would like to mount the new Stern switch without the protectors, Mantis and Ninja all together. When I make the attempt, I will photograph and document the process.
Quoted from Nevus:Looks like several of us Pinsiders are in the same boat on this one. I have the Mantis, Ninja and Stern kits in hand.
I doubt that there will be enough room to push the Mantis into the hole with the Ninja protector already in there. Probably a better option with the Cliffy though.
Quoted from ian866:I doubt that there will be enough room to push the Mantis into the hole with the Ninja protector already in there. Probably a better option with the Cliffy though.
If that ends up being the case, I'm going to simply install the Mantis protector and see how it does. Every Mantis protector I've used on new games over the years has performed perfectly. No reason to think otherwise for this scoop...
Great, look forward to your post! Much appreciated...
I have installed the RUSH v2 ninja protector. You can for sure see upgrades they did to the original. Looks nice. I also added the stern U fork w/ rubber nubs to the front scoop to further protect the right side of the front scoop being beat the hell.
Once this game goes home, i'll remove the stern U/fork thing.
IMG_5069 (resized).jpegIMG_5070 (resized).jpegWhat are we looking at here? I see a scoop hole that seems to be lathered in adhesive (and a missing bulb).
Northvibe, "I have installed the RUSH v2 ninja protector. You can for sure see upgrades they did to the original. Looks nice."
What do you mean the V2 rush ninja protector. What did they change. Since its release im not visually seeing any difference.
Quoted from Fordiesel69:Northvibe, "I have installed the RUSH v2 ninja protector. You can for sure see upgrades they did to the original. Looks nice."
I think they posted about it in their thread. Early units ripped between the two scoops. Also since I had had a tiny bit of art/clear coming up, they made another with extended pf side to cover that.
Ninja double scoop and ninja vuk protector, so glad I installed them.
My HIgh Score is 480M
Still clueless how to end an album.
and go to next album. The villa stangiato album super hard to end.
The spirit of radio is easiest to end.
Some way I collected 4 albums,
best I did so far..still clueless how it happened ..maybe was during multiball.
Quoted from northvibe:I think they posted about it in their thread. Early units ripped between the two scoops. Also since I had had a tiny bit of art/clear coming up, they made another with extended pf side to cover that.
I have one that ripped right in the same place you described. Will they replace?
20231204_211532 (resized).jpgQuoted from rdleifriaf:I have one that ripped right in the same place you described. Will they replace?
you will need to reach out to ninja camp mods.
That’s what happened to mine also. I contacted ninja and he sent me another one.
Hopefully bringing my Rush home so i can check out the scoops and protectors.... that scoop area...uffff.
Quoted from MikeSinMD:That’s what happened to mine also. I contacted ninja and he sent me another one.
What's the trick to getting them to respond to messages?
Quoted from rdleifriaf:What's the trick to getting them to respond to messages?
Post to this thread: https://pinside.com/pinball/forum/topic/ninjacamp-mods/page/23#post-7873733
That usually gets a response quicker than Direct Message.
This page was printed from https://pinside.com/pinball/forum/topic/rush-aftermarket-metal-scoop-protectors-/page/4 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
