Quoted from mnpinball:Need to also add the information that the new updated scoop protector itself is made with the proper hardness stainless that the first run pros did not get.
Unfortunately this is the risk you take by getting the first run pros out the door without any public testing but regardless at least the problem is fixed and is taken care of now.
This redesign update is very robust and should not give anybody an issue. Hopefully everybody with those early run pros gets this update quick and in their game up and running properly.
Is that different than the comical Benny Hill scoop protectors the LEs are arriving with? Those are just the Pro version with the wings literally cut off existing stock and two forklift forks to hold the top surface flat.
