Well, back for more.
Bought a replacement power supply on Amazon to see if that would sort things out. Same specs (I believe) as the one that came with ddebuss's kit - he gave it a thumbs up anyway.
Swapped it out and turned the clock on and... somehow I'm a little more confused.
So - last week. I reached to turn on the clock and saw a single LED lit at the bottom a column despite the clock being off. This had happened before. Turned the clock on and yep - faint vertical line lit up with a single LED out.
This is the picture from last week. The lights were on in the room.
Today with the new power supply - I plugged the clock in and BOO - a single LED at the bottom lit up again.
Turned the clock on and, well. The column is lit up as I expected, but it's considerably more faint.
This picture was taken with the lights in the room off and I can still barely see it. If it weren't for the single LED being lit when the clock is off, I'd never even notice or think to look. The picture barely shows it at all.
Weirder still - and this is where I hope someone here can say "Oh - this is clearly what's happening...."
I almost missed this oddity and ended up manually setting the clock to 4:09 just to make sure my eyes weren't playing tricks on me, but.
Today's very faint line? It's NOT the same line. It's one over. Last week it was the 2nd column from the right in the 0. Today, admittedly faint as can be, but it's the 3rd row in.
Out of curiosity I just swapped back to the original power supply and the lit up line is still really really faint and it's the 3rd row.
So what the heck is going on? I assume I can rule out the power supply being the issue? Per other suggestions, while waiting for the new PSU I did reseat both connectors on the DMD a number times and they all seem as tight as can be. I also redid the two wires that feed into the screw down connectors on the RUNDMD board and they're nice and secure.
What to try next? I do happen to have a spare 14 pin ribbon cable, but it's a bit different than the one currently in the clock.
I have one of these:
https://www.marcospecialties.com/pinball-parts/036-5260-00
whereas one side of the cable on the clock is soldered directly to the RUNDMD board.
Further ideas?
Edit - oh yeah. For what it's worth, that single LED at the bottom that stays lit when the clock is off stays lit even when the 14 pin ribbon cable is disconnected. No idea if that's pertinent or not.
Edit again - OK, the above isn't quite right. If the clock is off, a single LED in that row will stay lit, but it will vary if I remove/reconnect the ribbon cable. I've now seen the top LED remain lit and what appears to be one more or less in the middle of the column.
