New! Dark mode!
(Topic ID: 121699)
Run-DMD - The most amazing clock ever released!
By Limpan
5 years ago
  • 1,374 posts
  • 216 Pinsiders participating
  • Latest reply 3 days ago by ddebuss
  • Topic is favorited by 194 Pinsiders
    There have been 139 images uploaded to this topic. (View topic image gallery).
    16 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
    There are 1374 posts in this topic. You are on page 28 of 28.
    #1351 18 days ago
    Quoted from FatPanda:
    Just ordered a frame kit! Also ordered a MK2 board from Run-DMD's website limpan
    Does anyone know approx how long it will take to make the trip to the States?
    Usually it takes around 5-6 working days to a US address, but right now because of the pandemic it could take a week or two more depending on where it's sent and the current situation.
    #1352 18 days ago
    Quoted from Limpan:
    Just received notice that mine has shipped (within just a few hours of me ordering it). Thanks for the great service!
    #1353 17 days ago
    Quoted from Limpan:
    Awesome! Yeah, I wasn't sure with the pandemic if thing were extremely delayed from Sweden or not. I ordered a thing from the UK and it took like 2 months to get here. Funny enough, it was actually stuck in Chicago for a good portion of that time. Hope it doesn't happen for this! I'm excited.
    #1354 17 days ago
    Quoted from Mr_Tantrum:
    Cheers!
    Chicago seems to be a black hole. I lost two Run-DMD shipments there before the summer which both had Chicago as their latest registered tracking. Hopefully they get routed to a place with less problems now. A large portion of the parcels are usually sent with regular passenger traffic, so I guess regular airlines not flying as much as they used to is a contributing factor to the delays we see. Let's hope it reaches you faster than the UK parcel
    #1355 15 days ago
    Torbjörn has worked hard lately and together with firmware 3.60 that was released two days ago he just released the Run-DMD Control Center v.0.10 software which is available to download over at https://run-dmd.com
    Here's a little information about the application:
    Run-DMD Control Center” (v0.10) is the first release of a Windows based software for modifying or creating SD-card images for the Run-DMD. In this first version basic DMD/clock configurations are available along with the possibility to import images for use as clock backgrounds. To be able to use the ”background” feature, the Run-DMD must be running firmware v3.60 or later. (Any Run-DMD (regardless of board version) can be upgraded to v3.60 using a ”PICkit 3” from Microchip.)
    Run-DMD Control Center can read BMP, JPEG och PNG files and will resize them if needed.
    For best results use images with a resolution of 128x32 pixels. Use images with high contrasts!
    We hope to have additional features available in Run-DMD Control Center soon.
    More information and download link available here: https://run-dmd.com/run-dmd-control-center-v-0-10/
    #1356 14 days ago
    Sounds great, I hope future plans will allow folks to add/delete game animations as well?
    #1357 14 days ago
    For those wondering the same thing I was... can I update my firmware... from the site...
    Can I upgrade the Run-DMD firmware myself?
    Yes, if you have a PICKIT3 tool you can update the dsPIC33EP-type MCU on the Run-DMD.
    Run-DMD boards RevA/B/F2/F3 has a “ICSP” connector that you can connect the PICKIT3 to. If you have another Run-DMD board revision you need to remove the MCU and place it in a separate dsPIC33 ICSP socket for upgrading, this socket is available in the run-dmd.com shop.
    The firmware hex-files are available for download at run-dmd.com, please note the board revision and MCU type since they use different firmware hex-files!
    If you have questions regarding how to use PICKIT3, please refer to the microchip.com website.
    #1358 14 days ago
    Quoted from Strohz:
    The process of creating images for the Run-DMD is tricky, and includes a few different self developed tools afaik. Hopefully it will be possible in the future, but no news regarding that right now. You can show/hide individual animations or per game using the menus right now, but it would be cool if that would be able to do with the Run-DMD Control Center as well.
    #1359 12 days ago
    Run-DMD Control Center v.0.20 has been released with some new features. Run-DMD Control Center works great with earlier firmware versions as well, but the background settings will be ignored if you have a firmware lower than v3.60.
    Download link and info here: https://run-dmd.com/run-dmd-control-center-v-0-20/
    #1360 9 days ago
    From Stockholm to Fort Worth in 9 days - not bad.
    #1361 8 days ago
    For those of you who are interested in building the largest Run-DMD possible we are now happy to release the Run-DMD HUB12 Interface Board available for sale over at https://run-dmd.com right now.
    Together with 8 pcs. of HUB12 panels you'll be able to build a Run-DMD that measures around 130 x 32 centimeters (around 51.18 x 12.59 inches). STL-files for printing mounting brackets and link to HUB12 panels are provided on the product page.
    #1362 8 days ago
    Quoted from Limpan:
    What every wife would love in her living room above the couch.
    #1363 8 days ago
    Quoted from Limpan:
    AMAZING!
    #1364 8 days ago
    Bigger IS better.
    #1365 7 days ago
    Quoted from Limpan:
    that is awesome. where and how much for 8 hub12 panels?
    #1366 7 days ago
    Just finished assembling my Stern DMD version, and it came out great. I ended up repositioning the control board until I finally got where it aligned correctly with the menu.
    I also used the red lens behind the front smoke acrylic since I could see through it some without.
    Finally, there is a flashing red LED on the controller that was driving me crazy. After searching, however, there is a setting in the menu to disable it.
    767CB138-FD71-44C6-8536-A8535CF33737 (resized).jpegAF23BF11-8C27-48B5-B892-840133E43175 (resized).jpegF6ECFF87-1FF4-4287-B960-247C64A7E936 (resized).jpeg
    #1367 7 days ago
    Some pictures of my clock.
    Run-DMD mk2
    0F98DE37-61ED-4BAC-B4E4-E801EB0516A6.jpeg2920F8D3-2E09-4545-A882-1AD049F51721.jpeg79A55985-F113-4F10-97D9-3CB8D2C96F36.jpeg8E51387C-893B-4BEF-A21A-E55A9529DC93.jpegA86B756D-831D-45A6-BF2D-65C2A317C3DC.jpeg
    #1368 7 days ago
    Quoted from JHPSWE:
    Run-DMD mk2
    Love Love Love this! Would be cool to have the flipper occasionally flip and the pop bumpers flash or even use real pops and have them pop... Gotta thing through how to do that...
    #1369 7 days ago
    Wife is asking for Xmas gift ideas and I've always wanted to put one of these together.
    Limpan - any timeframe on when more MK2 kits will be in stock?
    Alternatively - I'm not against the Edge or Edge white, but need handholding on sourcing the appropriate displays.
    At the same time, I have no idea what the difference between HUB08 and HUB75 is. Am I right in that the HUB75 are RGB and can that you can select different colors? If that's the case and you want to be able to change colors - is there any reason to go with HUB08 over HUB75?
    Last but not least - anyone with experience ordering from aliexpress able to post links to HUB75 and or HUB08 panels that would work?
    Edit: or Amazon? I'm sure it's all coming from China regardless, but I do like Amazon's return policies should something go wrong.
    Edit again - I think all my non-MK2 questions became moot. Just got offered a free Stern DMD from a friend that did a Color DMD swap.
    #1370 7 days ago
    Quoted from Beatnik-Filmstar:
    More Pinball MK2 will hopefully be in stock in a week or two.
    Quoted from JHPSWE:
    Run-DMD mk2
    So cool!
    Quoted from boilerman:
    Around $45 for a set of 8: https://www.aliexpress.com/item/542728813.html
    #1371 7 days ago
    The link says they are Yellow, but your .gif above looks white?
    Also, which RunDMD board do I need for the HUB12 panels? I'm considering building one of these things.
    #1372 7 days ago
    Quoted from Spyderturbo007:
    It should be yellow. Probably the lamp in the gif making it look whiter. See earlier post with the Pinside background where it's a bit more yellow looking. You can either go with the Run-DMD Edge or the Run-DMD White (HUB12 interface board supports both).
    #1374 3 days ago
    In cooperation with our friends at Run-DMD.com we've secured a bunch of Run-DMD Pinball MK2's. Save on shipping to US and Canada and get faster delivery time by buying from gameroommods! The items that include the Run-DMD Pinball MK2 purchased before 12/1 will ship on or around December 15th for delivery in time for Christmas. Support for the Run-DMD products are still provided directly by Run-DMD.com. Go to https://pinside.com/pinball/market/shops/1167-gameroom-mods/02128-pinball-dmd-acrylic-frame-kit to see all of our Pinball DMD products.
    Black November "2020" Specials - Expires 12/1 or until supplies run out.
    Free shipping - Coupon "NOV-2020" (without the quotes) - Applies to most items in Pinside gameroommods store. Expires 12/1.
    1x Black Friday Special Complete Display $ 275.00 - Complete fully built and ready to use! Includes used Stern LED DMD, Run-DMD Pinball MK2 controller, Acrylic frame, and power supply.
    1x Pinball DMD acrylic frame kit with 1x Run-DMD Pinball MK2 $ 170.00
    2x Pinball DMD acrylic frame kit with 2x Run-DMD Pinball MK2 $ 335.00
    3x Pinball DMD acrylic frame kit with 3x Run-DMD Pinball MK2 $ 490.00
    4x Pinball DMD acrylic frame kit with 4x Run-DMD Pinball MK2 $ 635.00
    5x Pinball DMD acrylic frame kit with 5x Run-DMD Pinball MK2 $ 770.00
    6x Pinball DMD acrylic frame kit with 6x Run-DMD Pinball MK2 $ 900.00
    1x J_M_ Pinball DMD acrylic frame kit - Regular $35 / This month $30 (free shipping w/coupon)
    4x Pinball DMD acrylic frame kits - Regular $95 / This month $90 (free shipping w/coupon)
    5x Pinball DMD acrylic frame kits - Regular $110 / This month $100 (free shipping w/coupon)
    6x Pinball DMD acrylic frame kits - Regular $125 / This month $110 (free shipping w/coupon)
    The MOD Couple
    $ 48.00
    $ 4.49
    $ 12.95
    PinBoss Mods
    $ 229.99
    $ 26.00
    The MOD Couple
    $ 5.00
    Metal-Mods
    $ 299.99
    Top-Notch Target Shields
    $ 139.00
    Sparky Pinball
    $ 5,899.00
    Classic Game Rooms
    $ 25.99
    Lee's Parts
    $ 75.00
    $ 19.00
    The MOD Couple
    $ 7,599.00
    Gulf Coast Pinball, LLC
    $ 1.00
    € 35.00
    Creo Pinball
    $ 149.00
    Sparky Pinball
    $ 48.00
    $ 93.00
    $ 4.49
    $ 49.00
    Chrome Candy
    $ 99.00
    Lighting - Under Cabinet
    $ 76.95
