for anyone located here in the states, I can offer pic chips with the latest firmware. the price is $12 shipped. if you send me your old pic chip back, I will credit you $5
the current firmware is 3.48
here are a list of the updates that have occurred to the firmware since the dec 2015:
3.30 2015-12-05 New menu option "TOOLS"/"REBOOT"
Fix: Enabling/Disabling all or group of animations could corrupt data on some SD-card when using a HUB08 DMD
Displays progress when enabling/disabling multiple animations
3.31 2015-12-10 New clock styles "CELEBRATION" and "PIRATE"
3.40 2016-01-03 New option "DMD CONTRAST" (HUB08 and Pinball LED DMDs)
Support for Run-DMD EDGE (RevG)
New menu option "TOOLS"/"DMD DETECT"
Detects and reports communication bus errors with RTC or EXP board at boot
3.41 2016-02-17 Wake up timer setting is now AM/PM time format aware
New option "CLOCK OVERLAY" in menu "ANIMATIONS" to control if/how clock should be displayed during animations
3.42 2016-02-20 Fix: Slow animations/menu system using HUB08 DMDs with firmware v3.41
3.45 2016-02-21 New feature: "KEY TEXT" allows for two selectable custom text messages to be displayed instead of current time
Fix: Between animations Run-DMD could be less responsive to buttons being pressed
Fix: If only one animation is enabled the clock seconds dots could stop blinking
Fix: Option "CLOCK OVERLAY"="ON" would cause the small clock to be incorrectly displayed during some animations
3.46 2016-03-15 Fix: Custom message text displays time instead of entered text
Fix: "CUSTOM MESSAGE" and "KEY TEXT" displays incorrect texts when both enabled
Fix: Custom message / key texts not cleared by SD card initialization process
Current time and system temperature can be inserted in custom message / key text
Support for "EXP TEMP"
3.47 2016-04-01 DMD "HUB08-X" names changed to generic "TYPE-X" due to HUB75 support on Run-DMD RevM PCBs
3.48 2016-04-29 Selectable temperature scale (Celsius/Fahrenheit/Kelvin)
Configurable temperature display positions
Adjusted entry of temperature sensors (T1T2) in custom message / key texts
pm me for details with the subject line "run-dmd pic update"
