(Topic ID: 240246)
Run-DMD Jumbo displays in stock and ready to ship
By ddebuss
5 years ago
  • 2 posts
  • 2 Pinsiders participating
  • Latest reply 5 years ago by Flake
    #1 5 years ago
    I currently have in stock and ready to ship a number of Run-DMD Jumbo displays. Why settle for a itty bitty or average sized Run-DMD when you can have a Jumbo sized one for about the same price. This Jumbo display is "like" some of the other Run-DMD displays you may have seen except the pixels are a lot bigger and spaced a bit farther apart for a larger viewing experience. These are the displays you may have seen at the Texas Pinball Festival 2019.
    2 Jumbo clock versions available:
    - Jumbo RGB Run-DMD display with laser cut acrylic frame (~40"x11"x2") - $470 plus $30 domestic shipping.
    - Jumbo Red Run-DMD display with laser cut acrylic frame (~40"x11"x2") - $370 plus $30 domestic shipping.
    + Add customized ~40”x16” laser etched back and LED edge lighting kit to either display for $175. I will work with you to custom design the perfect etching for your display.
    The RGB and Red displays are nearly identical to one another except for the items noted below.
    Jumbo LED DMD Display/Clock common features:
    - Fully assembled plug and play as a Jumbo Run-DMD clock
    - Run-DMD controller
    - Jumbo sized LED panels for 32 x 128 pixel resolution.
    - Internal aluminum frame structure inside the display
    - Black glossy top and bottom trim (protective plastic applied for shipping)
    - Custom edge panels with power connectors and access to the Run-DMD SD card and buttons
    - Custom wiring harness
    - Heavy-Duty D-Ring hangers for wall mounting (~32" spacing) can be installed in 2 different positions.
    - Can sit nicely on a flat surface without mounting.
    - Power supply (5v/10a)
    - Power cord (US Grounded - 4' or longer)
    - Custom laser cut acrylic frame - Includes acrylic front panel (Grey tint), acrylic back panel (Black), and hardware kit.
    - Optional animation programming includes 2302 unique pinball animations.
    Jumbo LED DMD Display/Clock RGB version unique features:
    - Cutout to allow access to switches to set colors
    - Run-DMD White controller required for RGB panels
    - 4x 32x32 RGB LED panels
    - The RGB LED Modules in conjunction with the Run-DMD White allow for 7 different color display set before turning it on. Choose red, green, blue, yellow, magenta, teal, or white via the swtiches exposed in the back.
    Jumbo LED DMD Display/Clock Red version unique features:
    - Run-DMD Edge controller required for Red panels
    - 2x 32x64 Red LED panels
    I also have Run-DMD pinball displays and kits including all the components to turn your newish Stern DMD you removed to install a ColorDMD into a beautiful Run-DMD display.
    Order via gameroommods pinside store or PM.
    Display options for scale. Jumbo RGB Run-DMD clock - Back left, Jumbo Red Run-DMD clock - Back right, Pinball DMD basic kit - Left, Pinball DMD acrylic kit - Back center, Medium RGB Run-DMD clock
    Front view
    Edge view with power and button connections
    Rear view
    Note: The Run-DMD SD card has NOT been configured so it comes as a very nice clock. Unfortunately for copyright reasons I cannot preload the SD card. I will provide instructions on programming the card with the free animation file. You can also follow the instructal video here:
    #2 5 years ago
    We have one of these in our game room and absolutely love it. ddebuss does a great job and is awesome to deal with!
    This page was printed from https://pinside.com/pinball/forum/topic/run-dmd-jumbo-displays-in-stock-and-ready-to-ship and we tried optimising it for printing. Some page elements may have been deliberately hidden.
