2015.nov.23 - the list is now closed. I am no longer taking any more names to be added to the waiting list at this time
for a short time, I will be offering fully assembled run-dmd clocks
I am currently in the process of sourcing the remaining parts necessary to build one last fully assembled run of torbjorn/limpan's fantastic pinball animation clocks. all clocks are fully assembled, tested and carefully packaged in custom sized boxes for shipping with bubble wrap and packaging peanuts to ensure safe delivery.
upon delivery, the only thing that you'll need to do (after unboxing everything) is insert the 2032 lithium disc battery and connect the power supply cord to get the clock running.
pricing is set at 375usd plus shipping (I will ship globally, however except high shipping costs due to the size of the parcel).
the clocks from this run will feature the 4th revision of my acrylic frames, which will the following enhancements:
- screw holes for mounting the EXP ONE expansion board (sold separately)
- re-positioning of the run-dmd pc board to eliminate the need for the low profile ribbon cable connector
- a larger exposed section to allow easy access to the menu buttons, lithium battery and ICSP header / pic chip (for firmware updates)
assembly of the first batch of clocks will commence once the LED display panels and run-dmd pc boards arrive and the frames have been revised (probably mid-december)
shipping in 2016 per requests
Mayboyz - shipping 01.11.2016
completed/shipped orders:
tamoore, fattrain, huo, SilverballNut, S3G, pcb355, Toasterdog, kettchxxii, TheRoach123, BentleyBear
thall17, Jvspin, Ed209, Snake, MnHotRod, Redketchup, Magic_Mike, Patofnaud, T2play, eharan, pinmaniac
Brian_Pinball, SilverUnicorn, jeffspinballpalace, Kkuoppamaki, jletourn, daveispinball, pinlawyer, Cidco
PinBackPacker, Tbgolfen, Pdxmonkey, Toucanf16, C2Motorsports, shlockdoc, blueman01
