run-dmd - assembled clocks (batch 6)
By j_m_
1 year ago
Stats
  • 28 posts
  • 13 Pinsiders participating
  • Latest reply 1 year ago by Mayboyz
  • Topic is favorited by 11 Pinsiders
Find
Search this topic for posts matching certain words or written by a specific Pinsider. Or both!
    #1 1 year ago
    current stock level:
    25 SOLD OUT! (last updated 2017.feb.19)
    confirmed deliveries
    mvhulk, jhoward1082, jchristian11, out_of_order, PinballMagician, Bronte, mviltoncos, Teo76, jeffsarcade, CraigC, shenlung, PinballRx (x2), Medisinyl, badblackz, nobobo, local/buyers outside of pinside (9)
    >>> if you are interested in purchasing one, please shoot me a pm with your complete mailing information (so that I can calculate the shipping costs and give you a total amount due) <<<
    description:
    assembled using custom laser-cut acrylic panels, the clocks use (2) two P5 sized rgb LED panels, which are mounted side-by-side to display the 128x32 dot resolution (just like a pinball DMD). each clock measures approximately 28.00" (w) x 7.50" (h) x 1.50" (d)
    although the clock can only display monochrome colored animations, the user has the ability to select between one of 7 colors (red, green, blue, yellow, magenta, teal or white) by toggling the six dip switches accessible from the backside of the clock (see below for legend)
    the clocks ship ready to mount on the wall (with 2 hanging holes [16" on center]) or place on a shelf or desktop. only a small amount of assembly required to install the front panel with the enclosed hardware and tools
    (the front, transparent gray acrylic panel is shipped with the protective paper still attached to prevent it from getting accidentally scratched during transit
    the clocks feature a custom designed, laser cut acrylic front and rear panel. the front panel is a dark transparent grey (to neatly hide the internal components when the clock is not powered on) and a rear panel that is black, featuring material that has a glossy front side and matte back side (to help reduce/eliminate fingerprints).
    custom cut-outs in the rear panel allow access to: CR2032 battery, the power cable port, a 6-pin ICSP header to facilitate updating the run-dmd pc board's firmware and the 6 toggle switch block to change the clock's display color
    color selectable dip-switch settings:
    on-off-off-on-off-off = red
    off-on-off-off-on-off = green
    off-off-on-off-off-on = blue
    on-on-off-on-on-off = yellow
    on-off-on-on-off-on = purple
    off-on-on-off-on-on = teal
    on-on-on-on-on-on = white
    on - up, off - down
    information regarding how to adjust the many options found in the clock can be found here:
    http://www.phosphors.com/run-dmd/Run-DMD_v3.52_Menu_Navigation.pdf
    TomGWI's run-dmd clock from the last batch[picture shamelessly stolen from TomGWI]
    the cost per clock is $440 plus shipping, and each clock includes the following:
    - a mostly assembled run-dmd clock
    - (1) CR2032 lithium coin battery (to store all user defined settings and keep time when the clock is powered off)
    - (1) 5v, 10a power supply to power the clock with a 6' grounded 3-prong cable (north american standard)
    video of retromanIE's clock from the last batch
    #2 1 year ago
    OOOOOOK one for my pleasy !!
    #3 1 year ago
    Love mine thanks again!
    #4 1 year ago
    2017.jan.26 update
    the acrylic is on the UPS truck for delivery today. assembly and boxing of the first 10 clocks will commence tonight
    shipping will begin as early as tomorrow as payment is received
    #5 1 year ago
    Are the animations pre-installed, or do they have to be added to the clock?
    Is there a video of one running?
    I might get one.
    #6 1 year ago
    2017.jan.26 update II
    - acrylic received, unpackaged and low-tack backing stripped
    now commencing clock assembly mode
    bee-do bee-do bee-do bee-do
    #7 1 year ago
    Quoted from j_m_:
    nicely done.
    Love my clock.
    #8 1 year ago
    2017.jan.27 update
    - the assembly of 6 clocks was completed last night (those will get boxed today and shipped to those customers where payment has been received)
    - the assembly of remaining 6 clocks that I have components for [to be completed tonight]
    - the remaining 12 run-dmd [white] boards are set to arrive next week. assembly will commence once the parts arrive
    note:
    this may be the only run of clocks that I offer this year. there are a number of pinball and arcade restoration and few [other] projects that will take precedence
    #9 1 year ago
    I want one - please add me to the list
    #10 1 year ago
    2017.jan.29 update
    all clocks that I have run-dmd pc boards for have been assembled. the remaining boards should arrive this week.
    all clocks where payment has been received have either shipped, or will ship out tomorrow after I return home from work
    #11 1 year ago
    Quoted from Luckydogg420:
    I might get one.
    See post number one to see one in action
    #12 1 year ago
    2017.jan.31 update
    - the remaining run-dmd [white] pc boards have arrived today. modifying them to accept a molex power cable tonight
    - assembly of the remaining clocks will commence starting tomorrow evening
    #13 1 year ago
    Yes I would like one.
    #14 1 year ago
    Quoted from shenlung:
    if you're interested in purchasing one, send me a pm with your complete mailing address so that I can calculate the shipping costs and give you a total amount due.
    #15 1 year ago
    .....one coming in Italy....
    #16 1 year ago
    Bump for a cool product. Got mine and it's running great.
    #17 1 year ago
    2017.feb.11 update
    only 5 clocks left in this batch and I probably will not run another batch until september (at the earliest). if you want one, now's the time
    #18 1 year ago
    Received mine from j_m_ super quickly after ordering and it's awesome! Thanks again for taking the time to gather the parts and put these together for us!
    #19 1 year ago
    2017.feb.15 update
    ONE clock left.
    #20 1 year ago
    Wish I had the cash for this. This is freaking awesome!
    #21 1 year ago
    Hello,
    I take the last clock.
    Thanks.
    ps : I'm new member and I have to wait 24 hours before I can send a pm.
    #22 1 year ago
    Payment OK.
    I'm happy to be the last for this batch.
    Impatient to receive the Clock.
    #23 1 year ago
    Hello,
    Got mine and it's very amazing product !
    Thanks James for your professionalism very appreciate.
    #24 1 year ago
    Thanks James!!!! Arrived!!!
    -1
    #25 1 year ago
    His name is J.M., not James.
    #26 1 year ago
    Quoted from hlaj78:
    I think it is James, at least that is what my Paypal payment says. J.M. Are probably his initials.
    #27 1 year ago
    Very beautiful!!!!
    #28 1 year ago
    I have an extra clock i purchased that I'm not using. Mine is one color orange
    $380.00 shipped in the United States
    $ 29.99
    German-Pinball-Modular
    $ 16.95
    $ 24.50
    $ 194.99
    PinballBulbs
    Apparel - Unisex
    Pinball Wheezer
    $ 9.95
    $ 49.99
    $ 43.00
    $ 49.99
    $ 229.99
    $ 24.25
    The MOD Couple
    $ 38.00
    $ 5.00
    Metal-Mods
    $ 17.00
    BK Pinball
    $ 21.95
    Apparel - Unisex
    Pinball Wheezer
    $ 174.99
    $ 29.99
    $ 159.99
    Note: This is an old thread. The last post was made to it 411 days ago. Resurrecting old threads is not necessarily a bad thing, if you think the topic is still relevant and/or your post is beneficial to it (e.g. following up on something). In other cases, it might be better to create a new topic.
    Wanna join the discussion? Sign up for a Pinside account, or log in if you already have an account.
